HP LaserJet 4350 Printer Logo
Question about HP LaserJet 4350 Printer
How do i get rid of a "68.0 permanent storage full" error?
I have the 68.0 error and have tried cold restart and restarting while holding menu, restarting while holding cancel, and restarting while holding stop. Only the cold restart worked. Also, on my Mac the printer has an error message "OPC at end-of-life."
5 Related Answers
Anonymous
SOURCE: hp printer will not effectively cancel print
Solution by www.freaksmania.org,
We cannot turn off HP printers when the printing job is going on or it runs out of paper,Paper Jam or Cartridge runs out of Ink or any other reason,ie power failure.
To Cancel printing easily,
1)First plug out the Power Cable(the System tray icon will now disappear).
2)Plug out the USB Data Cable
3)Reconnect the power Cable and turn the printer on.
4)Turn the printer off again and Connect the USB Data Cable.
5)Turn on and then your existing printing Job will be Cancelled.
Solution provided by Team Freaksmania
http://www.freaksmania.org
http://www.freaksmania.org/forum
http://www.freaksmania.org/coderz
http://www.freaksmania.org/graphics
Posted on Dec 24, 2007
Anonymous
SOURCE: 0xc19ac3ff error code
Same deal. Message "ink system failure". I restarted the printer, it works fine
Posted on Mar 24, 2008
electronacs
electronacs
  • 19 Answers
SOURCE: Permanent Storage Write fail
It appears that there is a problem with either the internal hardrive if you have this option installed, or the removeable Jet direct card if you have one installed, thirdly, it could be bad memory or the main board.
Go to HP's website and perform a firmware upgrade for your model if there is one.
I would first remove any add on option like networkcard, memory .... then turn the machine back on and see if the error goes away. You can also go through the menu and perform a fatory reset, this however in the process loose your IP address.
Onece you have aliminated the options I would move onto the main board or FIRMWARE
Posted on Jul 07, 2009
Anonymous
  • 541 Answers
SOURCE: the power light is blinking, and wont stop
need more info on wot printer you have
Posted on Sep 21, 2009
Melissa Haskell
  • 161 Answers
SOURCE: HP PSC 1200 - Error blicking for Check Print Cartridges
replace ink.
Posted on Sep 26, 2009
Reopen the model phone of samsung gt s5300
Warning : by performing the hard reset will erase all fo personal data in internal storage, e.g. contact, message, reminder etc. Please do full backup first.
  • Turn off the phone
  • Press & hold volume up + home button simultaneously, then power on the phone
  • Release volume up + home button if recovery menu appear
  • Scroll down to factory data reset menu, use volume down to navigate and home button to confirm.
  • Phone will automatically restart and now the phone is on factory state.
Jan 22, 2013 • Cell Phones
Hp lj2420 errcode 68.2
The printer permanent storage is
full. Some settings might have
been reset to the factory defaults.
1. Press the SELECT ( ) button
to continue.
2. For 68 errors, turn the
printer off, and then turn the
printer on again.
3. If a 68 error persists,
initialize NVRAM. See the
caution and note in To
initialize NVRAM.
4. If this error message persists,
replace the formatter (see
Formatter).
HP Laser Jet 5500 DN Error 68.8 permanent storage error Clears after restart of the printer.
68.8 is a new one. It's not in the manual. The only two 68 errors I could find are 68.0 and 68.1.
In any case the 68 error says that one or more of the printer settings got hosed and reverted to its factory default.
Go through the printer settings and see if you can find what changed.
The easiest way to check is to print out a menu map.
1. press the check mark on the control panel
2. press the down arrow to highlight MENUS
3. press check mark to select MENUS
4. press down arrow to highlight PRINT MENU MAP
5. press check mark to select PRINT MENU MAP
After start my machine is shuttingdown and then restart oredy and show me this maseege: 49 error, turn off then on.
Power off , hold down the down arrow and the cancel button and turn the power on while still holding. Keep holding until permanent storage displays
If this doesn't work you can call HP 1800-334-5144.
1helpful
I want to cold reset my hp deskjet 3050 all in one J610 series so I can get my printer off Japanese and into english on the menu display. Can you help me with this?
1. Turn off the all-in-one.
2. Press and hold down the * and buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. Allow the all-in-one to return to Ready before using it.
After following these steps the printer should ask for language when it restarts. Keep in mind you will lose all other settings you may have put in.
1helpful
I have one printer lj 2420 68.0 permanant storage full error
Error 68 is simm memory problem.
68 Error / Service / Cold Reset
All printers
  1. Temporary error. Cycle power to printer
  2. Bad formatter PCB
LJ4, 4+, 4P
  1. NVRAM not initialized.
68 Memory
IIISi, 4Si, 4V
  1. Bad SIMM memory. Check and replace SIMM's
2helpful
2answers
Fax memory
Do a Hard Rebbot . Clear Cache
9helpful
4answers
Error 68.2 permanent storage write fail (Hp laserjet P4014n)68.2 permanent storage write fail. (for help press ?, to continue press ok) if i press ok it will print what ever job was sent but you have...
Hi! I will be glad to assist you in this issue.
Usually all you have to do is initialize hard disk even if you do not have one. Just turn off the printer. Turn the printer back on and when the memory starts to count hold down the menu key until all three lights come on. When all three lights are on solid release the menu button and press the arrow back button and initialize disk should appear in the menu. Just hit the check mark button again and it should take care of the problem.
here is the lin for additional solution:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpl12422&jumpid=reg_R1002_USEN#A46
2answers
My hp laserjet P4014n is giving an error message 68.2 permanent storage write fail what can i do to clear this massage?
Here is the link just incase you need more solution:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpl12422&jumpid=reg_R1002_USEN#A46
`permanent storage full error` what does it mean????
The internal storage system is full. You need to run the HP Web Jetadmin software and delete unnecessary files from the EIO disk device. When done, press the select button on the printer to return it to a ready state. You should be able to print small jobs yet as long as it doesn't require any temporary (or permanent) storage on the EIO disk.
Clive
Clive
Ben Johnson
