Question about DISH Network Televison & Video
Hitachi 42hdt79 Plasma TV Dish Network Code
I have a Dish Network remote 5.0 IR and have successfully gotten it to work on our Hitachi Plasma 42HDT79, but does anyone have a more specific code? Hitting select changes the language, the up/down or the tiny little arrows on the remote instead of the larger ones. Right now it's better than nothing, but thought someone might know a better code to correct it's annoyances.
    Top Expert:
  • DISH Network Master
  • 76,407 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Posted on Sep 06, 2017
5 Related Answers
catdaddygmr
SOURCE: Hitachi Plasma
i have dish network different brand tv but have codes for hitachi they are 1004,1006,1012,1013,1059,1060,1063,1135,1136,1145,1148,1179,1185. hope one of these helps
Posted on Dec 27, 2007
Anonymous
  • 51 Answers
SOURCE: dish network remote
i would suggest trying power scan again...
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
if this doesnt work try addressing your old remote to the receiver by pressing record from system info screen
Posted on Aug 06, 2008
Anonymous
  • 51 Answers
SOURCE: my one for all won't program...
dish network remotes are universal, you can program your receiver, vcr/dvd, telivision and stereo to most remotes. if you need info on this just post again, otherwise i would list your issue under the remote brand
Posted on Aug 29, 2008
Anonymous
SOURCE: Dish IR Remote 20.0 has problems after sunset.
The problem for me was the TV giving off IR signals that interfered with DISH's poorly designed remote. When the TV's room ambient light sensor was turned on and it became dusk outside the DISH remote would stop working. Moving the receiver away from the TV helps but the problem is not eliminated until the light sensor is turned off.
Until DISH corrects this poor design there may be no other viable solution.
Posted on Aug 04, 2009
Anonymous
  • 64 Answers
SOURCE: Hitachi 42HDT79 Plasma TV -
No, I'm sorry to say that the TV needs to check to find the problem. There is not way to just disengage the "protective mode".
If you would like to attempt to trouble shoot this yourself, you should obtain the service manual and with some electronic experince (maybe a friend) try to locate the problem. There is no one place we can direct you to with the information that you have given above.
You can obtain the manual by clicking on this - service manual
Posted on Aug 10, 2009
TENGO PROBLEMA CON UNA PLASMA HITACHI 42HDT79 SOLO SE VEN RAYAS DE COLORES VERTICALES SI HAY SONIDO Y ABAJO DE LAS RAYAS SE VE LA IMAGEN
Hola que tal oye porque cuando prendo mi tele Hitachi 42hdt79 se pone en standby se escucha todo pero no se mira nada ni le puedo cambiar de canal ni subir volumen
Aug 30, 2012 | Hitachi 42HDT79 42 in. Plasma Television
Codes and how to enter them for Panasonic Plasma tv for a Dish Network 1.5 IR Remote Control, model 113268
Hello Norma! My name is Becki, with DISH Network. I hope that you have gotten this resolved and your remote is working, but if not, here are some simple steps to program it! I hope this helps!
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
700
685
689
Becki Barned
DISH Network Customer Service
[email protected]
Jul 30, 2011 | DISH Network IR Remote Control
I have a hitachi 42hdt79 and yesterday the power just went off. the power button on the tv does not power it on nor does the remote. just dead.
The internal fuse, if you are lucky, may have gone. It is situated before the on off switch and mains filtering circuit board.
Jan 01, 2011 | Hitachi 42HDT79 42 in. Plasma Television
Can i run pc - hitachi 42hdt79? if so which cables to use? my pc has dvi & plasma has hdmi
You'll need to buy a DVI to HDMI converter (with sound)...They run about $40-60 online or You can change out your video card on the PC and get one with HDMI Those are cheaper
Oct 11, 2010 | Hitachi 42HDT79 42 in. Plasma Television
42hdt79 Hitachi TV will not power up. Cord is good TV is dead ??
Try the button on the front bottom, under the power button on the front.
Apr 05, 2009 | Hitachi 42HDT79 42 in. Plasma Television
Hitachi 42hdt79 tv guide on screen with not remember tv guide lis
Mine did/does the same,,,while in standby it also did/does produce a clicking sound intermitently.....now Pic and sound cycles on/off every 10 seconds or so. Intestingly...I could go on....but whats the point........JUNK Hitachi says "to bad" 26 months old and $800 to fix. Buy another brand........
Feb 22, 2009 | Hitachi 42HDT79 42 in. Plasma Television
Only receives 13 channels
try unpluging the set for a few minutes then re-do the auto search if that does'nt help upgade the software.call hitachi for this upgrade.
Mar 21, 2008 | Hitachi 42HDT79 42 in. Plasma Television
Audio quality
I fixed it by turning the main power switch off for thirty seconds and then turning it back on.
Mar 03, 2008 | Hitachi 42HDT79 42 in. Plasma Television
Televison & Video Logo
37 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
