RTO Mobil Line Mobility Scooter Chair Battery Charger31004 Logo
A
Anonymous Posted on Apr 23, 2014
How to you check the battery for the elite traveller scooter with a meter
1helpful
Where can I find a brake solenoid to order for a scooter traveler Go-Go electric mobility cart
Go-Go Elite Traveller (SC40E/SC44E) Parts - All Mobility Brands
https://www.monsterscooterparts.com > gotrmo > goeltrs
Items 1 - 155 of 155 - Order the Go-Go Elite Traveller (SC40E/SC44E) Parts from Monster Scooter Parts, and know you are getting quality scooter parts at a great ...
INFINFB2039 Go-Go Elite Traveller Series Troubleshooting
https://www.pridemobility.com > pdf > infinfb203...
PDF www.pridemobility.com ... NOTE: These instructions apply to the Elite Traveller, Elite Traveller Plus, and Elite Traveller Plus HD. Travel Scooters. ... What if the range per charge of my Travel Scooter diminishes over time? Determine if ... Check the charger fuse and ensure the electrical outlet is good. ... Solenoid brake trip.
Mobility Scooter Brakes for sale ' eBay
https://www.ebay.com > ... > Mobility Scooter Brakes
Results 1 - 37 of 49 - Get the best deals on Mobility Scooter Brakes when you shop the largest online ... 24VDC Warner Electric Motor Brake for Mobility Scooter & Power Wheelchair Parts ... DWR9983H019 Pride GoGo Brake Harness ... 24VDC 6.0nm Warner electric motor brake for Mobility scooters & power wheelchair.
1helpful
2answers
My gogo elite traveller wont chrage. The charging light isnt on when i plug the scooter in.
Sounds your batteries are to low in voltage for the charger to recognize. Also check the fuse on the battery box, normally a red one 10amps.
1helpful
How do i remove the battery from my go go elite scooter..?
If it is like my Pride Go Go Traveler Elite scooter, what they don\'t tell you is that you need to give the battery a sharp jerk to make it release and come off the scooter. You can\'t just pull it strong and steady.
1helpful
I need to re-set the potentiometer on an Easy Travel Classic scooter. Anyone have the procedure?
Hi all ,you need to do is make sure the throttle lever cross head is dead centre, got a meter ? then disconnected the throttle pot connector and measure one outside pin to centre pin , it should measure around 2.5k ( resistance)
Regards
Rob
www.gewizrepairs.co.uk
I have a go go elite traveller plus , the battery pack will not lift off my scooter it seems to be stuck , i need to replace the batteries
The manual for this scooter is at http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
The closest info I can find is page 14. MOVING AND TRANSPORTING YOUR Easy Travel Elite
6.1. Moving Your Easy Travel Elite in Freewheel Mode when unfolded:
The Freewheel switch (Fig. 1/17) is used for releasing the brake and moving the Easy Travel Elite without operating the motor. Before activating, make sure your Easy Travel Elite is switched on. Turn Freewheel switch to the "freewheel" position and push or pull the Easy Travel Elite manually.
NOTE: The Freewheel mode can only be activated after the battery is in place and the power switch (Fig.9/1) is turned on. Doing otherwise will cause a fault situation indicated by rapid flashing of the Indicator light (Fig. 9/4). See section 4.2.
WARNING: The Freewheel switch should never be engaged on a slope.
CAUTION: The seat back must remain in the upright position.
They seem to assume removal is obvious, I would check any connections from battery to scooter are pulled out and that freewheel mode is not engaged.
1helpful
2answers
Charging sterling elite 2001 scooter batteries
If you use the scooter every day then plug the scooter in each night for 8-10 hours.
My go go elite Scooter will not work. its only just over a year old. it's not been used for a few months. When put on charge the charger shows its fully charged. When the scooter is swithched on the volt...
It may still be under warranty.  What kind of reading did you get from the batteries? If they are below 12.0 volts they may have a poor memory. If you leave a chair un-charged for a long period of time the batteries can discharge to a very low level. The charger cannot bring a battery up from 11 voltsDC. You will need a slow car type charger or new batteries.
2helpful
Batteries are charged, scooter won't move, no power to display
It is impossible to overcharge with the Pride charger. When the battery is full, it will stop charging and check about oncew a miute to maintain the charge.
Now, when you plug in the key (looks like an audio headset jack) does the battery meter indicate a full charge? Also, the scooter will not move if its in free wheel mode, and it will not move if the charger is plugged in. Beyond these first steps, you will need a voltage meter to troubleshoot.
Top RTO Health & Beauty Experts
Rob Hill
Rob Hill
Thomas Perkins
Thomas Perkins
Harsal Patel
Harsal Patel
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
