Question about Advent Microwave Ovens
No display on advent microwave in rv
Model p90d23AL has internal light but no display
I have a Advent microwave model P90D23AL everything works but will not heat food.
It sounds like the main fuse is blown. Remove the cover to access the fuse (UNPLUG THE UNIT BEFORE DISMANTLING).
Advent rv microwave shows no power
Advent camper microwave shows no power but when you open the door the light comes on and turn table turns but on power on the screen shows nothing
Where can I get a new glass plate for my Advent microwave?
I have a few microwave plates.
You need to know the diameter, and the design on the bottom center
[email protected]
Sharp Carousel Microwave Mdl 1875 for our RV is dead
>> We also tried plugging our toaster into the microwave plug outlet, and the toaster wouldn't work in that outlet, but worked just fine in a different outlet in the RV.
This means the outlet you plug your microwave into needs to be fixed in addition to fixing the oven. Breaker? Fuse?
>> I understand from another RV forum that microwave ovens for RVs have "special circuitry and cooling features" not found in regular countertop ovens for household use.
Not really in my experience. Any microwave supplied with clean AC power and proper venting space will be fine.
But I'd bet your microwave can be fixed affordably.
The main internal things which can result in this model being dead (no display, no light when you open the door, no beep when you press a pad on the keypad) would be the 20A fuse and the magnetron temperature fuse. There could also be bad connections on the noise filter board.
Also, sometimes a power surge can cause the power to be interrupted to the low voltage transformer on the board, and I regularly repair those boards. I can also write a technical statement to your insurance company or to an RV park as needed.
At my Web site, I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The relevant service manuals for this model are here and here.
You can order Sharp parts from Sears or Encompass.
Contact me directly if you need more help.
- William E. Miller, AS-EET
[email protected]
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
1helpful
Hamilton Beach hb-p90d23al-dj keeps blowing fuses
If the microwave oven is less than 7 years old the problem is in the magnetron, " the most expensive part " or the inverter board, either way costly adventure, good for target practice.
Microwave Ovens Logo
Top Advent Microwave Ovens Experts
Gerry Harvey
Gerry Harvey
john h
Are you an Advent Microwave Oven Expert? Answer questions, earn points and help others
