Question about Samsung SCX-6555N Imaging Unit SCX-R6555A
How do I find the old imaging unit and replace it with the new one?
HEMANT GROVER
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 171 Answers
This si the drum unit
Posted on Oct 02, 2015
Just replaced the image unit of c352 and is still asking me to replace it. Please, what should i do?
which image unit? mite have gotten a bad one? clean the contacts on the small chip underside front of the image unit . SURE its new not some old one.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 17, 2016 | Konica Minolta bizhub Office Equipment &...
Need to replace imaging unit . konica c252
http://www.precisionroller.com/imaging-units-for-konica-minolta-bizhub-c252/products.html
push down, slide out, pull tapes and fixtures off new unit(s) and replace. These IU's have chips in them to keep track of life. Another option instead of replacing the unit is to buy just the chip and replace it on the old image unit. This depends on the condition of the existing unit(s).
Jan 07, 2015 | Konica Minolta BizHub C252
C-2551 error code
Check the cyan image unit. Pull it out and shake side to side to spread the developer in side the image unit along the whole length of the image unit. Then reseat the image unit. if the code comes back replace the image unit with a NEW one do not use old one hanging around. Also recommend using OEM cartridge.3rd party can cause problems. could also be a circuit board (Expensive). But have a tech re-flash firmware before replacing board
Aug 06, 2014 | Konica Minolta Bizhub C300 All-In-One...
ON A Di251F MESSAGE REPLACE IMAGING UNIT
Then you need to get a new image unit when you open the right side cover the device with the two handles on it pull out and replace it. Try the web site below, that is a old machine if you can find the image unit. Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 17, 2013 | Minolta Di251 All-In-One Printer
Minolta bizhub 164 black and white, change drum
Remove the imaging unit from the copier. Unscrew the sides. Remove the old drum. Replace with the new one. Clean the blade and everything of imaging unit including the waste or recycle part.
Jan 23, 2012 | Minolta bizhub 350 Black and White Copier
How to replace imaginging on bizhub 35
Open the front door/cover.Slightly push down the imaging unit which you want to replace.Pull the imaging unit outward, make sure first push it downward then pull it out towards yourself.Imaging unit will come out easily.After doing this, open up the new imaging unit.Remove its covering.Now put it straight, Green drum should be downward.Fit it to the machine from where you pulled out the old one.There are sliding at both side of imaging unit.make sure it sits perfectly in the machine gap.after inserting the imaging unit push it inward until it stops.If you heard a clicking sound then it means imaging unit has been fitted.
Jan 14, 2012 | Konica Minolta bizhub C250 All-In-One...
Re: Samsung Printer CLX3175FN -- receiving message "Replace imaging unit soon." I've read other expert replies but am still missing some information. Can I replace the unit myself? How do I do...
Nancy, Your imaging unit has a limited lifecycle. Documentation states that it can make 24,000 B&W pages and 6,000 color. The message is telling you that you are getting close to that limit. Eventually you printer will stop printing, and your messahe will state "Replace imaging unit". This can be done by you. It is very easy to do. The imaging unit is fairly expensive: around $150 or more depending on the merchant and shipping charges.
Drew
Feb 16, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Poor quality black output
There is a defect in the Imaging Unit of these printers....if you replace the imaging unit, the problem of the faded black prints go away. If you have less than 7000 prints, you can call Samsung for a warrantied replacement. The Imaging Unit is supposed to last at least 20,000 prints.
Nov 04, 2008 | Samsung CLP 300 Laser Printer
Bizhub C450
sounds like the wrong image unit. Oce and ollivetti have the same machine and take the same image unit but with a different chip. Make sure it is a genuine konica minolta image unit. If need be try putting the chip from the old unit on the new one and see if lays down the colour
Jul 10, 2008 | Konica Minolta bizhub C450P Laser Printer
Samsung SCX-6555N Imaging Unit SCX-R6555A Logo
56 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
