Kenmore 30 in. 42701 / 42702 / 42709 Electric Cooktop Logo
A
Anonymous Posted on Apr 23, 2014
Kenmore 790.9420 cook top does not heat up - Kenmore 30 in. 42701 / 42702 / 42709 Electric Cooktop
36" kitchen aid electric induction cooktop power comes on but burners don't get hot
Induction cook tops do not heat by convection... only the cook ware gets hot. Your cook ware has to be made or encapsulate ferrous materials. More simply put; if a magnet won't stick to the pot it won't work on an induction cook top.
Jun 09, 2019 • Cooktops
tip
Proper Use and Care of Ceramic Glass Cooktops
Here's some helpful tips that can hopefully ensure many years of quality use of your ceramic glass cook-top.
NOTE: It is important to maintain PROPER care of your ceramic glass cook top as they can be very expensive to replace. Prices vary between models, but most are in the $200 to $300 range. With added labor charges, this repair can cost over $600 from an appliance repair company.
WARRANTIES: Most manufacturer warranties DO NOT cover cosmetics. That is, if your cook-top paint starts to wear off from normal use, or from the selection of cookware you choose to use, manufacturers typically WILL NOT replace it. Warranties also DO NOT cover accidents such as dropping something on the top and chipping or breaking it. Some warranties WILL cover, however, blistering, warping and heat related breakage that were no fault of the consumer (as long as you were using the recommended cookware). It is important to become familiar with, and follow, all the manufacturer's use and care instructions that come with your range.
CERAMIC GLASS CHARACTERISTICS:
It is normal for the ceramic glass to change color when heated. This is especially true for lighter colored surfaces. The color should return to normal when cooled. It is also normal for the enameled or painted areas on the cook top to show signs of wear and fade over time. Proper cleaning and cookware selection can extend the cook top appearance.
It is NORMAL for the radiant heat surface elements to glow red and cycle on and off. There is a thermostat associated with each individual element that regulates the temperature. The frequency at which the elements cycle on and off is determined by the heat setting.
PROPER COOKWARE:
Use ONLY flat bottomed cookware for the best results of heat transfer from the surface elements. Cookware with warped, rounded or ribbed bottoms can cause uneven heat transfer which can result in uneven heating of the cooking surface and cause damage to the cook-top such as cracking and/or permanent surface discoloration.
An easy test you can use to determine the flatness of your cookware, is to turn the cookware upside down and place a ruler across the surface. As you rotate the ruler around the surface perimeter, you should not see any light along the ruler edge where it meets the surface. Cookware with slight indentions or expansion grooves can still be used, however.
Make sure the cookware bottom is always clean and dry before use to prevent any foreign matter from burning to the cook-top surface and leaving stains. ALWAYS place your cookware on the cook-top surface BEFORE turning the surface elements on.
Make sure the selected cookware matches the size surface element in use. The cookware surface should NOT exceed one inch beyond the radiant surface element surface.
COOKWARE CHARACTERISTICS:
The material of the cookware you select will determine how well it transfers heat and how evenly it cooks. The ideal cookware should be of medium to heavy thickness.
NOTE: A non-stick surface will take on the characteristics on the base metal used. (i.e., non-stick over aluminum, will take on the heating characteristics of aluminum).
*ALUMINUM - Heats quickly and evenly, light weight, suitable for all types of cooking tasks.
*COPPER - Heats quickly and evenly, light weight, suitable for all types of cooking tasks.
*Both aluminum and copper are great when used as a core metal cover with a non-stick or enamel surface. However, when used as a base metal, alone, they can leave metal transfer marks on the cook-top surface which will have to be cleaned immediately following use.
GLASS or CERAMIC - Heats slowly and unevenly, may scratch cook-top surface if there are any rough edges, best results are when using low or medium heat settings.
CAST IRON - Heats slowly and evenly, maintains heat for slow cooking, great for browning and frying, rough on cook-top surfaces, may scratch.
STAINLESS STEEL - Heats quickly and unevenly, a base or core of aluminum or copper can provide more even heating.
DO's and DON''T's:
DO NOT store heavy items, such as jars, cans, pots and pans above the cook-top surface. Any inadvertent dropping on the cook-top surface and cause cracks or shattering.
DO NOT lay hot lids on the cook-top surface. Heated air can become trapped under the lid creating a hot spot as the rest of the cook-top surface cools. The cook-top surface could potentially crack when the lid is removed.
DO NOT slide cookware across the cook-top surface. LIFT cookware as much as possible when moving from surface to surface. This will minimize metal transfer marks and scratching.
DO NOT cook popcorn in prepackaged aluminum containers. The aluminum could potentially melt and may not be able to be removed from the cook-top surface.
DO NOT store anything on the cook-top surface that could melt (such as plastic and aluminum foil). Once melted to the surface, some of these substances may not be able to be removed.
DO NOT store empty pots and pans on the cook-top surface.
DO NOT attempt to use the cook-top surface while the oven is on a self-cleaning cycle. The oven super heats to temperatures in excess of 500 degrees and causes radiant heat to be exhausted from the oven vent on the stove surface.
DO NOT use a cook-top that is cracked. Any spill overs could potentially leak into the radiant heat elements and create an electrical hazard.
DO clean up any spills from the cook-top surface that contains milk or sugar. You may allow the cook-top surface to cool in order to safely clean, but do not allow these substances to remain on the cook-top for extended periods. If not removed, these substances can cause permanent discoloration and stains.
DO wipe down the cook-top prior to, and immediately following use, to maintain the surface appearance.
DO NOT attempt to cook any foods directly on the cook-top surface without a pan!
CLEANING and CARE:
Clean all spills and boil overs immediately.
Any substances that become adhered to cook-top surface can be removed by wiping up excess with hot soapy water and a kitchen sponge.
Use a non-abrasive pad (the green kitchen pads are considered non-abrasive) and a straight edge razor blade, pushing in one direction to remove stubborn particles.
Some metal transfer marks (copper and aluminum) may be removed by simply wiping cook-top surface with a damp sponge. Any remaining marks can often be removed with an approved cook-top cleaner.
Use only approved, non-abrasive cook top cleaner to keep the surface clean and polished.
DO NOT use scouring pads that will dull or damage cook top surface (i.e., steel wool or SOS pads).
DO NOT use any harsh chemicals such as ammonia or bleach that can etch or dull cook-top surface.
on Apr 19, 2011 • Cooktops
Why is stove top displaying symbols not recognizing pots? Had stove 6 weeks, pots are correct and been used on this stove. Displaying on all 3 cooking areas.Can I correct it or is it faulty?
lets review this
please advise readers
maker of cook top so they can find the user manual
model or how old helps also
its not a gas cook top
you have the right type of designed pots for that cook top
but you get no heat radiating to the pot base
when pot is in contact with the heat area
Aug 17, 2016 • Cooktops
Cook top indicator lights stay on long after it has cooled off. The largest cook circle sometimes doesn't reduce heat when the dial is changed
Cook top indicator light will stay on as long as the stove is hot I think. Also, the burners don't heat real steady? or evenly or true to their settings even, quite often. they also take a really long time to cool down as well as to adjust temperatures, so it may just be that it is taking an awfully long time for it to cool down in order to adjust.
Apr 04, 2015 • Cooktops
I replaced what I thought was a bad 9" heating element on my Kenmore glass top stove and the new element still does not work or even attempt to come on. what should I do next?
Did you check if electricity was coming to the element. Try putting a volt meter on the two wires and turn it on see if you get anything...could be a bad switch
Won't heat all settings
Locked cook-top? Check breaker, fuses, plug
Jenn Air ElectrCook top One of the cook top heater is not working
well it can only be a few things on a cooktop... u either have a bad element or a bad switch.......usually on most to replace either u must lift top up and out and remove the screws all the way round to open unit up...hope this helps let me know how it goes
Feb 26, 2010 • Cooktops
12helpful
4answers
A metal pot lid was set on top of the ceramic cook top. Moisture was on the lid and it is stuck to the cook top. It will not move at all. How do I remove it without damaging the cook top? Should I turn...
In case anyone else encounters this problem here's what
worked for me. I had this happen last night and came here
searching for answers. It did not unloosen on it's own
after being left overnight. Finally this morning I came up
with something that worked for me. Shoot the lid all
around with a hairdryer and use a towel to keep seeing if
it has loosened up enough to move. After a few miuntes of
spraying it with the heat it stared sliding around and then
came up.
My Kenmore cooktop will not heat properly, all 4 burners. They turn on and heat a little bit, but the burner on lights do not light up and the burners do not heat to full temperature. I closed my oven...
hi my name is mark, a service tech needs to check the voltage to the cook top. you will probably find improper voltage. check data plate for proper voltage should be 208v or 230v depending onwhere you live.
Top Kenmore Cooktops Experts
Kolbrun...
k24674
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
