SOURCE: cd rw/dvd combo drive GCC-4242N WRITING PROBLEM
what brand , model number, and operating system you are using,,,
SOURCE: cant play DVD on CD-RW/DVD-ROM Combo Drive
Assuming you have tried different makes of cd or dvd disks, it's a classic drive failure problem where the laser can no longer burn or read dvd's, but may still be able to read cd's only. You will have to replace the drive, they are quite inexpensive, and very easy to fit.
SOURCE: CD-RW/DVD-ROM BURNER
if you wish to burn cd's which is your burner then you need a software called nero burning rom or any other burning software that lets you burn data or audio cd's or vcd's to burn with if you wish to burn dvd's then you need a dvd burner combo drive which lets you burn dvds
SOURCE: dvd writer doesn't read or burn dvd/ but only read CD-R plz reply to [email protected]
have you installed the softwares to burn DV/CDs? maybe you hadn't installed the softwares yet. normally samsung uses NERO. check the installation kits.
SOURCE: how do i replace dell optiplex 760 cd-rw/dvd
Here is the link to the service manual for your computer, since we do not know what formfactor the case is, go to the link, pick your case form and look through the manual for case opening instructions. Be sure to save a copy of the manual for yourself for a refernce.
http://support.dell.com/support/edocs/systems/op760/en/sm/index.htm
