Question about Magic Chef MCWC30MCG Compact Wine Cooler
Hot cooling and shows EFF code
Appears to be able to set a temp but does not cool
1 Related Answer
Anonymous
  • 10 Answers
SOURCE: Motor very hot; not cooling
If the compressor is hot it is possible that it is short cycling. Make sure the compressor is running and that the condenser fan motor is running if air cooled.
Posted on Mar 07, 2009
Have Gibson furnace runs cycle but seems don't get hot enough out of vents check all 115 degrees at vents use to lot hotter old furnace you couldn't stand on vents now you can easily
Is this a gas furnace ? Newer high eff. gas furnaces do have cooler outlet temperatures. The installer should have checked the temperature rise and gas pressure. By adjusting the gas pressure and blower speed you can obtain a higher outlet temp, but you don't want the gas pressure to be higher than the manufacture specs and you don't want the furnace to run outside of the manufactures temp rise specs.
Mar 02, 2017 | Gibson Heating & Cooling
Wfg36ilvq stove display shows "cool" and can not get it to work or even set the time.any ideas?
self cleaning stoves have a door latch mech that latches the door when cleaning (due to hi temps involved 4 safety) at the same time the display says clean and hence after clean cycle it says cool this will occur till the stoves internal temp reaches less than 100 degress , now stoves have to b insulated so cooling down can take many hours again this is 4 safety , now if next day stove still says cool then id say thre is a fault in the internal temp measurement of stove and it "thinks" stove is still hot
Dec 19, 2016 | Kitchen Ranges
95 caprice started smoking yesterday.. It was a lot of smoke but the temp gauge didn't say that the engine was running hot.. What could this be and why didn't my temp gauge show that it was hot
Have you lost cooling fluid, or oil? If fluid is non existant, the Temp gague may not have enough information, or it hasn't been operating for some time, especially if there is no cooling fluid.
May 05, 2015 | Cars & Trucks
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 05, 2017 | Heating & Cooling
Auto Camry 97 cooling fan is not switching on automatically, the temp gauge shows normal temp. Also both AC and cooling fan works when AC is switched on?
If the temp gauge shows normal, you would not expect the fan to be on much. It is controlled by the coolant temp sensor. If the fan will not come on when the car gets really hot, it is possible this sensor has failed.
It is normal for both AC and cooling fans to be on when you turn on AC to cool setting.
Oct 27, 2013 | 1994 Toyota Camry
Hi, I have a 2008 chevy colbolt I'm having problems with my cooling fan fuse, the num 2 fuse keeps blowing out, seem like it gets really hot then blows out. and the cooling temp on the dash show the...
No that temperature is not too hot for your engine. The system is apperntly kicking in at 240 from what your saying and then it starts to cool itself down. One of your fans may be going bad if you keep blowing fuses.
Aug 03, 2011 | 2008 Chevrolet Cobalt
Hi , our room is getting hot and more hot, it is 35 deg celcious now, how can we set the temp?
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Feb 04, 2011 | Heating & Cooling
My 1988 2.8L olds cutlass ciera stalls without warning and is a devil to restart. It appears to happen when engine is hot, check engine light flashes off and on, then starts no problem when it is cold. The...
1- check for codes with scanner to see why check light coming on. 2 unbolt exhaust before caterlic convertor. Run car to see if still does it.If it does not the caterlic converter is the problem.the car temp should not go over 220 degrees. if car is getting to hot it will shut off,check cooling system and cooling fans to make sure they are comming on. Also if water is flowing through thermastat.Map sensor when gets hot could cut out. some places to look. doug
Aug 28, 2009 | Oldsmobile Cutlass Ciera Cars & Trucks
Cooling fan
so hard wire a kill switch
Jul 30, 2008 | 1999 Chevrolet Cavalier
Magic Chef MCWC30MCG Compact Wine Cooler Logo
Top Magic Chef Furniture Experts
Sheldon Dedek
Muntejaya Ginting
Muntejaya Ginting
Are you a Magic Chef Furniture Expert? Answer questions, earn points and help others
