Question about Samsung PN Televison & Video
Samsung PN43F4500 error pings, what do they mean?
3 beeps in a row, every 5 minutes!!!???
4 Related Answers
Anonymous
SOURCE: 5 series' of 5 beeps in a row on start up
Check the Air Bag Indicator Light. When you turn the car on it should stay on for 6 seconds and then turn itself off. If a fault is detected in the system operation check, the indicator light will either fail to light, stay on continuously or flash. The flashing may not start until up to 30 seconds after the initial systems check.
If there is a fault in the system AND the air bag indicator light fails to light then an audible tone will alert you- it will be a set of 5 chimes (bells/beeps) five times in a row.
Have the Air Bag serviced and the indicator light bulb changed. Since the dash will be off in order to change the bulb, I would have all of the other dash lights changed at the same time. If one goes out, others will surely follow.
Corri R. / Service Writer
Posted on Jun 05, 2009
imufo2
Leo Ponder
  • 3773 Answers
SOURCE: I have a frigidaire ffhs23131s
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 10, 2011
gopakumarg43
  • 76416 Answers
SOURCE: I need to know whar 5 led stand by flashs means on my samsung pn43f4500 tv
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Oct 29, 2016
gopakumarg43
  • 76416 Answers
SOURCE: samsung pn43f4500 TEVELISION
LED Blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Oct 28, 2016 | Samsung Televison & Video
Samsung pn43f4500 TEVELISION
Oct 28, 2016 | Samsung PN43F4500 43-Inch 600Hz Plasma...
Samsung pn43f4500 error codes
Healthstream Evo Treadmill. When I turn machine on, all I get is 3 Beeps. The screen display has 8 rows,The 6th row is fully on. The bottom the alpha numerals,the center led of each unit is also lit.
Sounds like a fault in in the treadmills computer system the beep3 are error alert sound meaning somethings has gone wrong inside or the motor is reporting jamb fault code etc and its displaying with the lights upon the display board an error code a treadmill enginer will understand
Jul 12, 2016 | Washing Machines
What is 3-3-2 beep tone meaning
System doeIf there is one DIMM in the system the memory row/bank may be disabled when there is a memory failure. The system will not boot because it has no memory to use. If the DIMM is replaced with one of the exact same type and size, then the system will continue not to boot. BIOS cannot tell when a DIMM has been replaced with one of the exact type and size, therefore BIOS believes it is still the bad DIMM and will not use it.
Here are two possible workarounds:
1. After replacing the defective DIMM, continue to reboot the system until you hear the "no memory" post beep sequence (3-3-3) during POST (no video display). After three (3) incomplete boots, a "062 three consecutive boot failure. Using default CMOS configuration caches are off" error will occur. At this point BIOS will go back to the default settings and begin to use the new DIMM. However, if you have disabled the 3 boot fail count (this setting may not be available in all servers) in Setup, then BIOS will not turn the DIMM row/bank back on.
-=OR=
2. Remove the DIMM. Power on the system until the "no memory" post beep sequence (3-3-3) is heard. The memory row/bank will now be marked as being empty. Power off the system and put a good DIMM back into the system. The memory DIMM row/bank is re-enabled and the system boots normally.
NOTE: If more than one DIMM (or more than one DIMM set) is installed in the server and one memory (or one memory set) row/bank is disabled due to a memory failure then, the user must go into setup and re-enable the row/bank after replacing the bad DIMM.
Additional information
s not boot after replacing memory DIMM Servers
Jun 11, 2014 | IBM Netfinity 5600 8664 Server
Can I watch movies using USB?
The TV does not support
HDDs (Hard Disk Drives)
connected to the USB port
this is from the manual. Here is a link to it:
http://www.manualslib.com/manual/784978/Samsung-Pn43f4500.html?page=6#manual
Probably only for mp3s or jpg images.
Feb 13, 2014 | Samsung PN43F4500 43-Inch 600Hz Plasma...
My Brother MFC-5440CN states machine error 7E. Help!!
error 7e means "no head parameters stored in the eeprom".
1) locate the head data sticker at the front left of the machine. it should have a 12 digits number at the top row and headx..... at the second row. the data is the 12 digits number. if the sticker is missing somehow, there's another one at the head/carriage unit.
2) enter maintenance mode.
3) enter 6 and 8 for property data entry
4) enter 2 5 8 0 within 2 seconds and you're at the data entry state.
5) key in the 12 digits number. use # and 1 to 6 to enter letter a to f.
6) hit the ok button. machine should beeps and display "input accepted". if it say "input error" there's a checksum error, meaning you keyed the number in wrong. it will return you to the data entry state.so just key the number in again (step 5).
7) exit maintenance mode. done.
Nov 21, 2009 | Brother MFC-5440CN All-In-One InkJet...
Phone beeps during calls
check if this a minute beep during on call, you can find it on the menu settings , call settings.
hope this initial info helps you.
micro
Mar 21, 2009 | Samsung Cell Phones
My zoom x6 modem doesn't block pings (ICMP). How do I configure?
Blocking ICMP pings on a Zoom requires a few steps:
1) Go to Advanced Setup and select Advanced Firewall Filter.
2) Enable Advanced Firewall Filter.
3) Click on Security Policy Configuration.
4) Click on Policy Rules for "Add Firewall External-Internal Filter Rules."
5) Click on Add Policy Rule.
6) In the row labeled "Protocol," select "neq" and enter ICMP where it says "(Protocol Number or Name)."
7) In the row labeled "Select the direction to filter packets," select BOTH.
8) In the row labeled "Filter Action," select DENY.
9) Click on Save Changes and repeat 1) through 5).
10) In the row labeled "Protocol," select "eq" and "TCP." Below, select BOTH for direction, and ALLOW for filter action.
11) Save changes and repeat 1) through 5).
12) In the row labeled "Protocol," select "eq" and "UDP." Below, select BOTH for direction, and ALLOW for filter action.
13) Save changes.
14) Go back to Basic Setup and save changes to Flash.
That's it. Good luck!
Jan 26, 2009 | Zoom X6 (5590) DSL Modem (55900003)
Televison & Video Logo
57 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
