Question about Kenmore Side by Side Refrigerator
How to fix a leaking water dispenser? - Kenmore Side by Side Refrigerator
Posted by Brad Cowgill on
Lewis Meyer
    Scholar:
    New Friend:
  • 140 Answers
Remove the service panel, look for a loose or leaky hose. hose is inexpensive and easy to replace. if its coming from the cylinder and is cracked or split, it will need to be replaced. many companys will give you a 1 year contract of buying there water they deliver and you get a free water cooler.
Posted on Apr 24, 2014
1 Related Answer
Anonymous
  • 373 Answers
SOURCE: Leaking water dispenser
check the "drain pan". during defrost cycle it is filled completely.Try to shift the water out of it during every defrosting cycle.
Posted on Dec 22, 2008
Water dispenser leaks
Refrigerator Water Dispenser Leaks?
Refrigerator Water Dispenser Leaks show that the refrigerator's water system has a problem. To fix this problem, open the filter compartment and pull out the filter and push it back in so that it is secure in place. Push compartment cover until it clicks.
try to check this video.
May 13, 2014 | KitchenAid Superba Architect KSCS25INSS...
Sounds like the water valve isn't seating properly, so a small amount of water gets by causing the leak. Replace the dual water valve.
Mar 24, 2014 | Refrigerators
Hello. My G.E. Monogram water dispenser trickles water after we get water from it. We have to keep a cup there to catch the excess water. How do I fix it so it stops as soon as we get water out of t
Try replacing the Water Valve. It is located in the back of the refrigerater, left side. You should see three tubes connected to it. This part fixes the following symptoms - Leaking water, Water dispenser will not dispense water, Ice maker will not make ice and Ice maker won't dispense ice. GE part#WR57X10032. The Water Valve is extreemly easy to replace. Only takes about 15 mins total time to remove, install and confirm. I just replaced mines..my problem went from leaking water to no water was dispensing at all. I have the GE Profile, it uses the same water valve as your GE Monogram. There is a You Tub video that also shows how to replace. Good Luck!
Dec 27, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Hsm25gftsa
This problem is common and can be difficult to solve, first of all you have a air leak and because of this, your dispenser leaks. Check every connection for the water system, starting from the back of the unit at the valve. Disconnect the water to the tank first, put the water valve in a bucket and hit the dispenser switch to see if the valve leaks after dispensing water, if it does, replace valve, if not continue in to refer section behind crispers. (this is behind the veggie bins can you see any water at the bottom? If so, repair the leak and continue forward. Check under freezer door at the connection to assure not leaks of water. Again this is a process and after all of this is done or check, one of these solutions should solve your issue. I know not a simple answer but this will correct the issue when everything is checked.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 29, 2013 | Hotpoint (HSM25IFTSA) Side by Side...
GE Profile TPX24...water leaking from under freezer side...water dispenser works fine, but ice maker not working properly. What could be the problem...and how do I fix it?! Thanks
i had the same issue twice. 2 suggestions 1) Remove the front grill at the bottom and you will see a plastic water line. Inspect it to see if it is leaking. Turn on the water dispenser when you are looking at the line. 2) pull out the refrigerator and remove the lower panel. Follow the plastic water lines to a solenoid valve and inspect the lines when you activate the water dispenser. water may leak from where the lines go into the solenoid value. if may be a simple fix like cutting the ends off the lines and reinserting into the solenoid valve.
Jun 14, 2009 | GE Profile TPX24PBDCC Side by Side...
Water drip at doorfront water dispenser
Hi!!! Yes you can fix it by installing an antisyphon device on your water line leading to the water dispenser..remember i've done this for many years repairing frigs and they all do this they all leak water out alittle bit..Good luck..
Jan 03, 2009 | Refrigerators
Slow leak from the water dispenser
water or switch i beleave is the water valve
Dec 18, 2008 | Kenmore 53082 / 53084 Side by Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
I think I would think about getting a new one. It would cost more to fix it and then you may not get it back together so it wouldn't leak.
Dec 21, 2007 | Refrigerators
Kenmore Side by Side Refrigerator Logo
49 people viewed this question
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
