Canon MultiPASS MP390 All-In-One InkJet Printer Logo
Question about Canon MultiPASS MP390 All-In-One InkJet Printer
How do you get Print head stuck to the right unstuck? Attempted to clean print head, etc. through Additional Funtions-Maintenance, and printer sounds like it's moving the print head over, but it doesn't and then there's a click, click, click. Also, display reads wrong cartridge. Can this be fixed?
5 Related Answers
Anonymous
SOURCE: Smartbase MP390 Printer - error ##345
canon smartbase mp390 error ##345 check printer can anyone help me
Posted on Feb 08, 2009
Anonymous
SOURCE: Print head is not installed. Install Print Head
Installed 2 new factory spec. print cartriges.
Posted on Feb 13, 2009
Anonymous
SOURCE: My Canon mp390 printer doesn't print
I had this problem several times, had to buy new print head until I found that to clean it you should use ammonia. It really worked for me. You should really try ammonia it does work.
Posted on Jun 14, 2009
Anonymous
  • 2306 Answers
SOURCE: "Wrong Cartridge" - what to try next?
Cleaning won't help this one, you need a new printhead,QY6-0034-010. It only says wrong cartridge when the printhead is burned out.
Posted on Aug 11, 2009
Testimonial: "Thank you for the expert info."
Anonymous
SOURCE: Canon MP530 print head malfunction
I had the same problem with my printer. There is a switch that tells the printer that the cover is open or closed. Unplug the printer. Open up the printer cover and look on the inside right side edge. About half way back, you'll see a 3/4 inch by 1/2 inch hole where this switch resides. If you put your finger into it, you may be able to push on a lever and it will go down. It should spring back up when you pull your finger out. If you can feel the lever but it just sits at the bottom then there either this lever is broken or the spring fell off.
The problem with my printer was the spring had popped out. To access the switch, you'll need to remove the right side cover. Do this by removing the two screws in the back on the right side. Open the printer cover and find the third screw. It is located on the right hand side, near the front of the printer, on the top. Remove this screw and pop out the cover and see if you can find the spring that is attached to the lever. Make sure you do this in an area that if a small piece fell out you could find it.
Look at the switch and lever. If there is no spring attached to the lever then it is most likely the problem, otherwise the switch may be bad or the electronics inside the printer. There is a hook on the lever and one on the printer. Reconnect the spring and it should fix the problem. I found my spring had completely fallen out and fell on the floor when the cover was opened. It is possible that this spring if fallen out can fall back inside the printer so you may have to shake the printer to find this little spring. It is about 1/2 inch long. Hope this helps.
Posted on Sep 10, 2009
Canon ImagePrograf 750 Error: Execute printhead cleaning. If this message is still displayed, replace the printhead. Printing stopped.
It sounds like you have already tried a few steps to address the issue. Here are a few more things you can try:
  1. Turn off the printer, unplug it from the power source, wait a few minutes, and then plug it back in and turn it on.
  2. Check to make sure the printer is not in an error state. If it is, clear the error and try printing again.
  3. Try cleaning the print head manually. To do this, remove the print head and use a soft, lint-free cloth to clean it. You can also use a cleaning solution designed specifically for print heads.
  4. Check the ink cartridges to make sure they are installed correctly and have enough ink. If they are low or empty, replace them.
If none of these steps work, it may be best to contact Canon support for further assistance. They may be able to provide additional troubleshooting steps or offer a repair service for your printer.
1helpful
Black ink in printer not printing out but color ink prints out fine
The black print head is faulty or blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Black ink is not dispensing right
Clean the print head then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Print head Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the print head:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Bought used BJC-85 - feeds paper - won't print with new cartridge. Must have been dry too long. Where do I get a print head for it? Or a cleaning kit? I need it right away for a trip.
No need to change the print head. Just carry out all the maintenance tasks with the new cartridge. Make sure that you remove the thin plastic film from the ink pad. All you have to do is to click on printer/faxes in control. Click on properties in the drop down menu. Click on the maintenance and carry out each task i.e. print head cleaning, alignment, nozzles cleaning etc.
1helpful
No Printed documents
Have you performed a print head cleaning? If not, follow the instructions below:
1) Press <Menu> on the panel repeatedly until [Maintenance] appears on the display
2) Press left or right arrow buttons until the cleaning setting you want appears, either [Head Cleaning] or [Head Refreshing]
3) Press the <OK> button.
Note: Head cleaning should be attempted first, and may need to be done more than once. Examine the results of the test page.
Head refreshing is more aggressive, uses more ink and should only be performed when necessary (ie. when multiple head cleanings failed to solve your print problem).
1helpful
2answers
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
2answers
Will not print
New Genuine EPSON Cartridges.
Used print head Cleaning Utility from the printer maintenance and computer at least 3x consecutively.
Straight answer, printer is having a hardware failure (print head part). Having it repaired costs more than buying a new one.
Read information about EPSON Loyalty Program here - you'll benefit from it.
Printer update
Print Head Cleaning / Head Refreshing If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head. NOTE:
a. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
b. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
  1. Press <COPY> or <PHOTO>.
  2. Press <Menu> repeatedly until <USER DATA> appears.
  3. Press < (left arrow) or > (right arrow) to select [MAINTENANCE].
  4. Press <OK>.
  5. Use < or > to select [CLEANING] or [HEAD REFRESHIN] as necessary.
    [CLEANING]: Performs normal print head cleaning.
    [HEAD REFRESHIN]: Performs deep print head cleaning.
  6. Press <OK>.
  7. Print a Nozzle Check Pattern to see if print quality improved.
    4. Press <OK>.
    5. Press <OK> again.
      The machine prints a nozzle check pattern (A).
  8. If broken or white lines appear in the pattern, perform two Head Refreshings (from steps 1 through 6) then print another Nozzle Check Pattern.
  9. If print quality does not improve after two Head Refreshings, replace the appropriate ink tank.
Confirming The Nozzle Check Pattern
Broken lines
sj402061.jpg White lines
sj402062.jpg Click here to return to step x to perform Head Refreshings
Clive
Clive
old marine
old marine
