Question about Sony KP-46WT510 46" Rear Projection HDTV
My Vizio LED m470sl 47" tv has Verticle bars of lines that run horizontal. It also seems to be pulsing from light to dark. It's almost as if its refreashing every few seconds. When it pulses the controler input lags for a second. There is a picture on the screen and the lines only appear if there is input on the screen.
SOURCE: horizontal green lines the whole length and width of the screen
Hey, I had the same problem with blue and red lines and this post helped me bigtime ! Just adjust the color your having problems with. Best Solutionposted on Sep 12, 2006By maddogmic Rank: Not rated Rating: 100%, 1 votes I had the same problem with my sony KP-57ws500 rear projection tv. To solve this problem all you need is a flat and phillips screwdriver. Right below your speakers on the right and left side are tabs. Pull out the tabs and remove the screw on eachside. Once that is done remove the speaker cover and you will see a fiber board cover in the middle of the tv, there will most likley be twist ties holding some wires, to make it easier to work remove the ties. Now remove the screws on the fiber board and pull it off. You should see 3 adjustments on the top for focus, do not touch those. Below the focus adjustments on the
Posted on Sep 27, 2006
SOURCE: No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Posted on Aug 18, 2007
SOURCE: Lines in picture
You may have to re-adjust the screen drive. It sounds as though it may be just a bit high. If it's not that, you may be getting a bad picture tube. I hope this has helped in some way.
Ed
NC Electronics
Mills, Wyoming
Posted on Feb 18, 2008
SOURCE: Sony KF-50WE610 flashing power/standbylight
Its small board with few connectors and easy to replace.
You can buy required part from Part Store. You may see image of ballast supply there.
Posted on Jan 18, 2009
SOURCE: my sony clicks green led flashes but no sound no
Hi,if your tv is 2-4 yrs and have not replaced the lamp it might be time to replace it.Do you hear clicking noises and have replaced lamp before it could be the board that powers the lamp its called the ballast.You can find original philips lamp in here : http://www.discount-merchant.com/SearchResults.asp?Search=XL2100+?Click=48173 Have a blessed day!
Posted on Nov 12, 2009
