you need to change the paper size or font size in the software that creates the printout. if you can, do a print preview before you print to see if its going to try and print to one page
contact the developer or programmer of invoicing system. i believed the problem is in hard code in which your newly installed HP printer not supported with the invoicing system application.
Go 'Lists' and then open 'Templates', double click on the product invoice and make sure the invoice is 'Active'. Qbooks saves printer settings for each feature, regardless of which is set as 'default' in Windows...be sure you have the correct printer selected. If the above are set correctly, go to HP's website and download the latest driver for your printer.
Sounds as if the format is wrong. You must set the paper format in the PC wordprocessor or invoicing software to the same size as the actual paper size of the invoice.
Press the select button so light would go off than press 2 buttons marked menu than press print,this will print out the menu settings .When done press the group button till rear group prints than press item till page lenght prints,now press the set button till the desired page length is reached,than press exit button to save setting and exit from menu.Power off the printer then power back on should be ok .Hope this helps.
dezzi
It sounds like it needs to be re gapped. Try this: 1. Make sure that printer power is off. 2. Press and hold the feed button. 3. Turn printer power on. 4. When the status light blinks, release the feed button. 5. The printer advances the media to measure and verify the length of individual labels or tags. The printer then prints a status summary and remains in diagnostic dump mode. 6. To begin normal operation, tap the feed button. The printer prints "out of DUMP" and advances a label.
