It depends on the pump but most pumps have a filter bowl with a screw on cover - you need to fill this with water and start the pump. if the pipework connected to the pump and the filter are empty you will usually have to repeat this process a few times, but once the pump is primed it should start up without repriming in future - Hope this helps - Nigel
The most common causes of no prime are that the filter pot is not filled
with water (don't forget to put the cover with a gasket on), there is
an air leak in the pipes/valves between the pump and the pool, a plug of
leaves or other debris in the suction line, or the pump is installed so
high in elevation relative to the pool that just a little of the above
issues will prevent it from priming. I hope this helps.
If
this answer does not resolve your issue, please comment with additional information
before rating the answer. Positive feedback is especially appreciated once your
problem is solved! Thank you.
