Your amp is under powered for those speakers (350 max. watt). Even if your subs were 2 ohm your amp will only put out 75 watts X 2 at 2 ohms, if you bridge that amp you might be asking for trouble . I'm guessing there both 4 ohm. Look around for a 2 ohm stable mono amp with more power and you won't be sorry. Ray
SOURCE: Kenwood KAC-8103D Power Amplifier wont turn on
it sounds to me like its burnt.but with some amps the screws that hold it in place have to be screwed into the car chassisfor grounding. be careful not to srewe into hidden wires.
SOURCE: amp goes dirctly into protect
ok well it could be two thing wrong your amp dont have a good ground or your amp is a smar amp and your subs must have to be hooked up so the power from the amp cn go to the subs so the amp can see that you do have subs hooked up to take it out of protect o and look at your fuses to to smal or to big will send it to protect to
SOURCE: i have a kenwood 600 watt kac-7285 hooked up 2 my highs
use bass blockers or use a crossover.
SOURCE: amp blows fuses
fuses blow to save the amp. Are your speakers too big for the amp? If this amp is rated RMS @ 16olms it will only power around 600 to 800 @ 8olm and less as you drop down. better to have too much amp then too little so if you are trying to push 1000 watts per speaker @ 8 olms you are way under powered. Also check to make sure your wires are correct inside your speaker cables
