Question about York Fitness Z16 Treadmill
Where to buy replacement fuses for z16
Pulso monitor states needs new fuse
Posted by Jo-Anne Elab on
Tom Campbell
    Scholar:
    New Friend:
  • 73 Answers
Often these devices use the same style fuses ("blade style") as modern cars. YOu may find what you need at the automotive section of WalMart.
Posted on Apr 24, 2014
Blows fuse power board
fuses are to stop FIRE.
when electronics shorts out, the fuse blows.
fix'g that takes skill.
and to do it efficiently a special tool is used,
we use a current probe to find shorts.
lacking tools, its 10x harder,
isolating parts, 1 by one and a box of spare fuses.
take it in the the geek squad, and go broke,or
buy a new monitor. (i have no idea the cost of yours $100 or $3000 ) nor its age or model number.
im a retired tech.
Ive even repaired, USN HUGE PPI radar monitors. that yes.
catch fire and **** out waves of hot stinking tar , out the bottom. SPA-4's.
ive worked it all. need help, post better , input.
model numbers and age of monitor.
Sep 29, 2013 | Microtek Computers & Internet
LG Monitor (L1933TR-SF) No power. Wife cntrl-alt-del and monitor shut down. Fuse? Lamp?
neither one. Almost all lcd, plasma, and dlp monitors utilize capacitors to form a static charge to energize the screen. Those capacitors are extremely tempermental, and can go out with no notice at all.
It will work just fine, turn off, then when you turn it back on, no power. Both Best-Buy and Fry's electronics have tech's that will replace your blown out capacitors. Most of the new monitors don't have fuses anymore, nor do they have a lamp in the traditional sense. They use a chip/grid system, and the capacitors energize the grid .
Dec 15, 2010 | LG W1953TPF 19" Monitor
The small ceramic fuse inside the monitor has blown. Where can I geta replacement, and what is its value. It is difficukt to read whether it is 3.15amp or 15am?
wvc12, You will need to look with magnifing glass. could be ".315a or 3.15a" Check with Newark for proper rating( fast-blo or slo-blo) . LittleFuse makes both types. Will also need to know first 2 or 3 letters in front of amperage. Also check "DIGIKEY.com" You will also need to determine if fuse blew from "old age" and just got "tired" or did it blow because some other active (solid state) or passive device has failed!!! Good luck with this one. 12fixlouie
Oct 18, 2010 | LG Flatron L1800P 18.1" LCD Monitor
My dell 2005fpw flashing screen
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
Jun 06, 2010 | Dell Computers & Internet
Clock and lighter do not work. elecrtic miiors
You need to replace the fuse. Look in your owner manual under index and look for fuse box location. Remove the fuse box cover and find the fuse that states cigar lighter or mirror. Remove that fuse and replace with new 15 amp fuse. Your fuse box should have a fuse puller and auxilary fueses
Jan 06, 2010 | 2000 Toyota Camry
Monitor Switch Part Number?
They might be referring to a diode connected to the big silver capicitor and screwed to the case.
These can go short circuit causing the fuse to fail.
Mar 16, 2009 | Microwave Ovens
Blowing fuses
Isn't the 1 amp fuse too small? Usually 12 volt operated electronics require a higher amperage fuse. Check with the adaptirs owners manual first before changing again.
Jun 10, 2008 | Disney D7500PDD Portable DVD Player
No power to monitor.
Hello mousemilk,
The monitor itself is defective and can be either:
1) Replaced under warranty
-OR-
2) Repaired at a local shop. If this is the case and you are NOT under warranty - the best solution is to buy a new monitor.
Take care!
Feb 24, 2008 | Envision EN-9250 19" Flat Panel LCD...
En7410 won't turn on
DONT WASTE YOUR TIME AND MONEY THE PCB(POWER CONTROL BOARD IS BAD YOU WILL BE BETTER OFF BUYING A NEW MONITOR)
IF you do find the power control board replacement and get it to work i think you would have better results spending the same amount of money on a new monitor with all new parts plus warranty
Jan 15, 2008 | Envision EN7410 17" LCD Monitor
York Fitness Z16 Treadmill Logo
142 people viewed this question
Top York Fitness Exercise & Fitness Experts
Tom Chichester
ray gallant
Marvin
Marvin
Are you a York Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
