Question about D-Link Computers & Internet
Use an Ethernet cable to connect from the port on the DSL modem to the WAN/Internet port on the D-Link modem.
Posted on Feb 02, 2015
SOURCE: Configuring EDIMAX 6104 for Aztech 600E Router
Does your router automatically set the ip addresses for each computer, or do you have to set them up yourself? Is the computer that can connect the one that is directly connected to the modem? if it does and you asked windows to repair the connection it probably is messed up. check in the router settings to see if your pc's are on the same ip address route (e.g 192.168.x.x), but not all the same last digit; and the subnet masks are all the same (eg 255.255.255.0)
Posted on Oct 26, 2006
SOURCE: ZYXEL P-660HW-T1 V2 WIRELESS ROUTER MODEM WILL NOT CONNECT TO MY ISP
is your router connected to your ISP ? (does your dsl led light up ??)
if no! check your wires from phone to router!! and check your SPLITER !!! (i had the same problem, i got bad spliter !!! NEW BUT FAULTY !!!)
chears
Posted on Dec 06, 2008
SOURCE: Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM [email protected] or through this website.
once
Posted on Jan 13, 2009
SOURCE: how to connect ADSL 2 modem to Wireless Router
just change the ip address in the router and give the proper settings in the router
Posted on Apr 04, 2009
SOURCE: I have a Bell DSL modem Speed Streem 6520,linksys Wrt160n &16port
How to Set up the Bell DSL modem: http://www.digitalhome.ca/forum/showthread.php?t=97732
Setting up a Linksys WRT160N Wireless Router: http://www.linksysbycisco.com/US/en/support/WRT160N
(Download the Manual from this site)
Setting up a Linksys 16 port switch: There are many different switch models, however if it just your basic switch, you should be able to just plug it in and plug in your computers via RJ45 cables.
If you need any further assistance let me know....
Serge
Posted on Apr 09, 2009
Apr 23, 2014 | D-Link Dir-835 Wireless N750 Db Router...
Jan 16, 2014 | D-Link Systems DIR-600L Wireless-N150 Home...
Nov 21, 2012 | D-Link ADSL2/2+ Modem/Wireless Router...
Nov 11, 2012 | Computers & Internet
Jul 09, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Jul 06, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Dec 31, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Dec 14, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Nov 04, 2008 | Computers & Internet
Dec 11, 2007 | D-Link ADSL2/2+ Modem/Wireless Router...
127 people viewed this question
