Press menu then start mono then 4 times arrow-up (Tel index). machine will be in maintenance mode. press 8 then 0 (zero) then press the start mono button until display shows error A1: xy. Press the right arrow (Speaker +) button. What error codes do you see? (Machine saves the last ten errors). plz post here again.
To leave the maintenance mode press 9 then 9.
You did right. Sorry, right procedure is: when reaching machine_err_1 A1 press menu button to switch to the next error code. Do this nine times (until machine_err_9). plz post codes here again.
OK. So the fax modul seems to be OK.
Did you had a look at the faq?
http://www.brother-usa.com/FAQs/faq.aspx...
It might be that the settings are wrong. Plz have another look into the manual chap. FAX and try the other settings.
SOURCE: I cannot send nor receive faxes.
Make sure the phone cord from the wall is plugged into the port marked"line" and not "phone".
Followed all of your instructions. Got to a screen which read "MACHINE ERR_1:A1" But when I pressed right arrow (speaker +) button, nothing happened. Pressed everything in sight but unable to get error log. Any other suggestions?
Thank you for your efforts.
Thank you for the additional effort. Unfortunately all I was able to get was the numbers 2 through 9 - there were no error codes. Pressed the arrow button at each number but no codes appeared. Now what?
