Question about Panasonic VDR-D200 DVD Camcorder
Panasonic vdr-d210 No Power
Greetings- I have the above panasonic model that will not turn on, a charged battery is installed and the unit makes no sound at all when any button is pushed. It would be great if you could advise on a possible fix.
Thanks, Dawn
Posted by trendsavvy on
  • 1 more comment
  • Anonymous Dec 25, 2007
    I would like to edit videos for my vdr-d-210 but there is no install disc to download software. who do I call there is no 800 number listed.
  • Anonymous Mar 03, 2008
    i had the cam for about 3 months but one day it would not turn on. i charged the battery fully and still woul not turn on. i dont know what to do. please help me.
  • waazzaap Mar 03, 2008
    same problem, i tried everything but it wont turn on. please help
2 Related Answers
Joe Hogan
  • 10865 Answers
SOURCE: I accidently formated my panasonic VDR-D210 DVD.
When you reformat again using the proper disk, you should be ok with formatting. Whether or not you can recover the video is yet to be seen. Regards, Joe
Posted on Dec 07, 2009
SOURCE: HOW TO FINALIZE THE DVD CASSETE AND CONNECT TO T.V SET?
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine.
DVD Formats: DVD-R, DVD-RW, DVD-RAM, DVD+R, DVD+RW.
How do I Finalise my disc?
  1. When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
  2. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
  3. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
  4. When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
  5. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
  6. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes.
Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Posted on Apr 23, 2010
Bought a new battery pack (jensen brand) for panasonic 5.8GHz gigarange supreme KX-TG6500 2Line cordless phone and it wont charge.
check that you got the right make of battery for the charger
some phones use a nicad battery and others use a lit ion battery
2 different recharegable batteries -- 2 different chargers required
Nov 29, 2016 | Panasonic Lands Phones
I have a panasonic CF-74. Suddenly it will not turn on or show that it is charging. What do I do?
On any Panasonic Toughbook, I would try to hold down the power button for 12-15 seconds continously unit you hear an audible beep and that will cause the unit to "reset". Then you should be able to power back on as normal. If this does not work, try unplugging the Toughbook, taking out the battery pack. Do not yet put the battery back in but plug it back in. Then try to start the unit. If this does not still work, then try holding down the power button again for 12-15 seconds. If the unit is just stuck in suspend or hibernate then one of these actions is almost certain to work.
Good Luck.
From Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
Jan 17, 2012 | Panasonic Toughbook CF-74 (CF-74HCDAZBM)...
Turn ringer on
Go to Settings > SOUND > Silent mode (No sounds except media and alarms).
If this is ticked (on), it means umts smartphone alarm will sound even if you make the phone silent.
Regarding the loud sound even after reducing ringer volume, no idea for this.
Dec 03, 2011 | Panasonic KX-TG2383 Corded Phone
I have a panasonic cordless fonr model number- kx-tg2521e and it has stopped working it says no link to base. reconnect ac adaptor can you help plz
sounds like battery is flat. Put phone on main unit and make sure the main units power cord is plugged in and turned on.
Aug 24, 2011 | Panasonic Lands Phones
My camera lens isn't working, how can I reset it?
it sounds like there is dirt, dust or something else in the lens mechanism. I'm assuming you don't want to take the camera to a repair shop. I've had several cameras and this issue comes up periodically.
You can try:
1. using compressed air (with as thin a nozzle as you can find) to blow out the dust,
2. try powering on the camera and zooming the lens at the same time, 3. gently knocking the camera on a hard surface to loosen the lens mechanism,
4. manually forcing the lens to go back in. This can potentially damage the camera, but it's not working now, so you don't have a lot to lose.
5. Googling the camera model to see if you can find instructions on opening the camera up to clean the lens mechanism.
Oct 09, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
How to power battery up propery for use
Hello sarajjd, your description indicates correct operation. The internal battery will require charging overnight. I will need Mgfr, make & model to confirm.
Nov 03, 2008 | Electronics - Others
I have a sony vio vgn-c140g and it wont turn on
You say your battery doesn't work? Try removing it and then plugging it in with your AC Adapter. If it boots now it's because of the dead battery. If it doesn't check whether it boots with just the battery installed. It's either your adapter or your battery.
If it boots without battery, but with adapter --> dead battery.
If it boots without adapter but with battery --> broken adapter. (this can have multiple reasons, loose internal contacts, insufficient power, short circuit)
If none of the above is the case then you should contact Sony for there might be a problem with it's internal power system.
If one of the above is the case however check your warranty and get either the defective part replaced. (or if possible check with someone else's first).
I hope this helps, please rate.
Greetings,
DarkNeogen.
May 22, 2008 | Computers & Internet
DELL INSPIRON 1000
Try the following:
1. Try to boot the notebook with both battery and adaptor attached.
2. Try to boot with ONLY the battery.
3. Try to boot with ONLY the adapter.
If you can't boot with only the adapter, the adapter has died. If you can't boot with only the battery, the battery is dead.
But as stated above, make sure your battery is sufficiently charged.
In case of a dead battery or adapter, check whether the device is still under warranty. Contact HP if so.
Let me know what you found out.
Greetings,
DarkNeogen
Jan 24, 2008 | Dell Inspiron 1000 Notebook
Answering machine replay is garbled
Your handset battery will have no effect on the answering machine audio, providing your regular audio is fine (its fine when you make a phone call right?), I will assume yes. I have seen this problem in these models, and your problem lies in your base station, and the only fix you can attempt is to go into base programming and delete as much as you can out of the memory, greetings, old messages, etc.. Power down, then power back up again. Call in and leave a message. See if it sounds better through the handset or the speaker on the base when you play it back. If its garbled both ways (reviewing through the handset or on the speaker base) , then your problem is in your base memory. If it is just garbled on your handset, then it may be a radio module problem with the base, either way it probably needs to go in for repair. I don't know if Panasonic still repairs that model, but if you google Panasonic cordless telephone repair, you will find someone. Good Luck, CG
Jan 11, 2008 | Panasonic KX TC1731 Cordless Phone
Panasonic VDR-D200 DVD Camcorder Logo
99 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
