Car sat in driveway around 6 months battery was dead so i purchased new battery and installed connected battery terminals alarm went off and cant turn alarm off with key fob remote do i have to reset something?
SOURCE: I have a 1993 Lincoln
we get all our wiring schematics at alldata.com
its well worth the money and you have full access for a year
SOURCE: Lincoln mark wont start.....
ive tried turning the ignition on and off three times or so....then turning it off completetly for about five secs and then turning the ignition all the way on and most of the time it starts up....but sumtimes i think this car has a mind of its own......
SOURCE: Lincoln Mark VIII wont start
if you tried to jump the veh. when the batt. died, then you may have fried a fusable link in the harness. use a test lite to (CAREFULLY) look for voltage leading away from the batt. also you may want to check and see if someone can hear the relay click on as you try to start. (it is sometimes hard to hear it, so you want minimum back ground noise). good luck!
SOURCE: My 1996 Lincoln Mark VIII will not start. It
Check your power to your fuel pump. Put your ear to the filler for the gas and get someone to turn on the key, do not crank.. You should here the fuel pump cut on. If not suspect pump problem. You can also take the lin loose at the fuel filter and check to see if gas comes out after key is turned on and work your way to the engine if you get gas there just follow the lines.
SOURCE: 2007 Lincoln Mark LT Key Fob
Theres only 1 way to tell if it will work - try it :)
Here is the procedure to marry a new remote to your truck.
1. Close all doors and then open drivers door and press
the UNLOCK
button on drivers door panel while door is open and insert
key in ignition.
2. Turn ignition
from OFF to RUN (not start) 8 times within 10 seconds, with the
8th time ending
in RUN. Door locks will cycle to confirm programming
mode.
3. Within 20 seconds press any button on first keyless
remote.
programming.
4. Within 20 seconds, press any button on second keyless
remote.
Door locks will cycle again to confirm
programming.
5. Turn ignition to OFF.
Locks will again cycle
to indicate end of programming mode.
Both the Escape and LT program the same - the transponder should have the same resistance.
Try it out!!
Thanks for using FixYa - a Very Helpful Rating is appreciated for answering your FREE question.
