Televison & Video Logo
Posted on Nov 02, 2007
Samsung tv i have no remote, can't change channel on tv itself, says PANEL LOCK, how do i unlock please.
  • 6 more comments
  • Anonymous Nov 24, 2007
    Lost remote cant change channel or volume because it says panel lock how can i unlock it ??
  • Anonymous Dec 20, 2007
    Accidently turned Panel Lock on dont have a remote to turn it off any ideas or suggestions
  • Anonymous Feb 27, 2008
    panel lock, lost remote, on channel 10!
  • katieeee Mar 02, 2008
    Accidently activated PANEL LOCK and cant turn tv on now , lost the remote control any ideas on how to unlock it?
  • Anonymous Apr 01, 2008
    same problem panel lock shows
  • louben Aug 28, 2008
    No remote and panel lock stuck on please help its my sons tv .....!
  • deancrompton Jan 05, 2009
    cant turn panel lock off and I HAVE remote control
  • Anonymous Jan 21, 2009
    panel lock displayed - no instructions
A
Anonymous
Sell it at a car boot sale
Froze
To see if the problem is with your remote control, go to the receiver and use the channel up/down buttons on the receiver itself. If you can change your channels with the buttons on the receiver, the batteries in your remote control probably need to be changed.
If you can't change channels from the receiver, turn off the receiver. Then unplug it for at least 15 seconds. Plug the receiver back it and turn it on. Again, try changing channels from the receiver itself.
Tune to a channel, and while programming is playing, try tuning to the missing channel by entering the channel number on the remote control keypad to see if channels change. Do not try to select the channel from a channel list, program guide, or favorites list.
If this approach takes you to the correct channel, you need to adjust your favorites list function. Press the "guide" button on your remote. Look for a button on your remote called "fav" or "list." Press it several times and watch for an indication at the top of the guide that you are moving from "all channels" to a particular favorites list.
If you are locked on one channel only, your Channel Lock feature is likely active. Consult your owner's manual to unlock the rest of your channels. See your owner's manual for information on managing favorite channel lists and locking out channels. Enter your password, if necessary.
My toshiba 27a45 tv says video lock when i change it to channel three how do i unlock it without the remote
To get more details about how to unlock Toshiba TVs, visit this site ,Electro-help'.
The colours on my tv screen are all green and distorted can you tell me what the problem is its a samsung and its only 2 years old
YOU MAY HAVE CONNECTED THE RECEIVER TO AN INPUT ON THE TV THAT IS INCORRECT FOR THE SIGNAL OUTPUT FROM THE RECEIVER.
GET YOUR TV BACK ON THE CORRECT INPUT OR CHANNEL...CYCLE YOUR TV THROUGH ITS INPUTS BY...PRESSING THE INPUT, SOURCE, OR TV/VIDEO BUTTON ON YOUR TV REMOTE OR THE TV ITSELF.
IF THE PICTURE IS NOT RESTORED, CHANGE YOU TV TO CHANNEL 3 OR 4 USING TV REMOTE OR THE TV ITSELF.
IF THIS IS A 2ND TV, TUNE YOUR TV TO CHANNEL 60-73 USING THE BUTTONS ON YOUR TV REMOTE OR THE TV ITSELF.
ONCE YOUR TV PICTURE IS RESTORED, PRESS AND RELEASE THE SAT MODE BUTTON ON YOUR REMOTE TO ENSURE YOU'RE IN THE PROPER MODE FOR CONTROLLING YOUR RECEIVER.
YOU CAN ACCESS YOUR FEATURES, SETTINGS ETC, ON YOUR MENU BUTTON ON YOUR TV REMOTE.
HOPE THIS HELPS!
MARTIE
Lost remote want to use a univerisal remote but tv say front panel lock How do I unlock it? 32 in westinghouse
On the TV itself, MENU, SET-UP, INPUT, VIDEO then go to Channel lock and de-select it.
Hope this helps. If you post a model number, I can probably get you a manual.
Good luck, R.J.
1helpful
Parental control code had been changed, don't know what it is now
Hello
Try the following to unlock your Jensen TV.
1. Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
2. Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
3. Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
4. Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
5. Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired.
OK.
7helpful
2answers
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Plays on wrong channel
ok i downloaded and read your DVR-1000 manual , this is what you will do .
While the DVD+VCR is turned off, press and hold CHANNEL (up/down) button on the front panel for about five seconds.
The unit will turn itself on and “RF 03” or “RF 04” appears on
the front panel display
Use CH ( up / down ) button on the front panel or CH ( up / down ) button on the remote control to change the RF output
channel (CH 03 or CH 04).
Turn the DVD+VCR off and then on
Set the TV to channel 3 or 4 depending on the RF
output channel you selected.
Now you can watch the DVD+VCR playback on CH3
or CH4 of your TV
PS , you should see a child lock button on the remote , if you press that button , you will disable front panel button controls so kids can't change anything , press it again to unlock that feature , it might come in handy.
Thanks for using Fix Ya .
J5
7helpful
8answers
Unlock Hyundai TV
motimoti 's solution worked. Thanks.
By the way, how do you find the solution ?
Tv switches source channel without warning
Hi Andy.
What is the samsung model number ?
http://dysonmanuals.llc.nu/
Chris...
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
