Question about Dishwashers
Hoover D73 Dishwasher water comes comes and goes, no washing
I just bought a used dishwasher (1 yr old) that was supposed to be working (but they haven't used it for a few months). When I start a program, water comes in and fills the bottom of the dishwasher, then it just sits there (there is a humming noise) but there is no washing and then at the end of the program it pumps out the water. Could anyone please help me. Thanks
Georg
Posted by argentina1 on
  • argentina1 Nov 02, 2007
    I turned the dishwasher over and moved the pipes on the bottom around a little bit and after that it worked.
drid
It sounds like the main pump is stuck.
Try lifting the dishwasher (or tip it on it's side) and locate the main pump. It's the large one that has a white rotating disk attached to it for ventilation. Rotate this disk a few times with your finger and give it a try. You can also check that all the cables are attached correctly to the pump and capacitor (white cylinder near the pump)
Posted on Sep 20, 2014
paul proctor
  • 4,102 Answers
This is a problem with the timer programme at the end this can be replaced but can be tricky to do your self the water should drain freely out of dishwasher if you feel confident enough taking the back off try finding the drain pipe because uselly these get blocked with either the food off the plates and it can get blocked with limescale if it hasnt been used for a while then the mess has buitl up and set hard if you can get the drain pipe off try running some bleach through it but make sure you clean all the bleach off before putting it back on otherwise everything will smell of bleach this is the only sollution it does sound like the drain p[ipe is blocked the dishwasher will cut off if the water raises in the bottom it does this as a safety feature to stop your kitchen from flooding it is more than likely a blocked pipe so check this properly and the drain in the bottom of the dishwasher as the water shouldnt just sit their it should be draining all the time but i would say clean all pipes properly before you do anything else hope this is some help......................
Posted on Nov 02, 2007
  • paul proctor Nov 05, 2007
    if this is the case then it sounds like one of the pipes are blocked if you are confident enough to take the pipes of then run some descaler through them as if you are living in a hard water area then this is the problem it is not a major problem just get some good descaler and run this through as it cuts off when the water raises past a certain level as a safety measure this should solve your problem hope this is some help
The water softener will not recycle or what ever the term, automatically
you have a problem with the the Regen gasket. Depending on what you paid for unit plus repairs, you might consider purchasing a better from home depot. I had a sears, but tired of having to repair it. tossed it out and bought unit from hd used about 1/4 of the salt.
Aug 24, 2018 | Kenmore Dishwashers
How to reset a Kenmore 668.1687582 dishwasher
Yes, depending on the model, and the buttons that your dishwasher has, try the following key sequences:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry). You will know that you have entered the diagnostic cycle when all the lights light up for a few seconds.
On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 03, 2012 | Kenmore 24 in. 15142 Built-in Dishwasher
White residue left behind. Glasses come out pure white! had dishwasher for yr. and half and worked great! Now the last few months this white film is left and dishes are not coming out as clean. I use a...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Oct 26, 2010 | Whirlpool Dishwashers
Hi I got an HE2T front loader. its 1 yr 1 month old. i place clothes turn to cycle door locks drum turns they get wet they sit there drum turns once or twice they sit there few min it drains then goes to...
was the trip in house knocked of at any time ,sound like it was knocked of its cycle.Push and hold the on/off button in for about 5 secounds this should reset the program and if tha fails push and hold the on/off botton plus one other botton and hold the both of them in for about 5 secounds.adrian,,,,,,,,,,,,
Aug 11, 2010 | Kenmore 46462 Front Load Washer
Regarding Maytag Dishwasher, model # mdb4651aww3. Most of the lights on the control panel will not light up. You can't change cycles or set the delay timer etc. You can hit the start button and it runs a...
I have same problem with my Maytag. Had a repair guy come out and he said it's the 'controller card', not the button touchpanel. The controller card is $127 and not in stock and there's a 'several month wait'. I'm not going to wait, going to buy something used for less than the price of a new controller card. Maytag's quality has really deteriorated in the past few years. They used to have a 5yr warranty on pretty much everything - now it's only 1yr. (and of course, mine failed just a few weeks after the 1 yr time.
Jul 25, 2010 | Maytag 24 in. MDB4651A Built-in Dishwasher
Vista
try using another web browser like mozila fire fox or opera. other wise u have to uninstall the internet explorer and reinstall it again. to uninstall in windows(xp)
* click on start--control panel.
*click on add/remove programs then click on ad/remove windows programs at the left corner of the pop up window.
*among the windows components, check for internet explorer and untick it then click on next to continue.
*when don restart yr system
to reinstall internet explorer
*follow the steps above to tick internet explorer thyen next n yr don.
it should work i suppose.
May 24, 2008 | HP Pavilion dv6000z Notebook
Residue of dood,spices on dishes after cleaning
I would suggest calling whirlpool to have a tech come out and look at it. Your appliance is still under warranty if it is under 1 yr old. It will cover parts and labor.
Nov 17, 2007 | Whirlpool 24 in. DU915PWP Built-in...
Dishwashers Logo
283 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
