Question about SanDisk Sansa e200 MP3 Player
I can turn my sandisk player on but its stuck...
This is how it happened a few weeks ago after xmas i dowloaded songs on to my new pink sandisk mp3 player.. then i upluged it said uploading reneing library and it froze there so i turned it off. now i can turn it on and off but when i turn it on the bluw light comes on then turns off and the screen is left on the logo screen and doesnt go past that: ive replaced batteries and took it in to bestbuy they didnt help at ALL! i hope u can help me!:) Erica i was listening to my mp3 player and then i turhed off to do something else and then in a couple minutes i turned it back on and the scroll lit up but the screen didnt and after a few seconds it unlit. When i plug it in to my computer the information comes up and the scroll works the same but the screen still won't comme up.
Posted by mikalman on
Timothy D
  • 626 Answers
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Posted on Nov 03, 2007
1 Related Answer
Anonymous
SOURCE: I can turn my sandisk player on but its stuck...
I had to get 2 sansa 250's as they both did that after feww hours all by their selves. No files were transfeder and was only using fm function. after calling factory they said to return to store or send to factory, maybe they could fix it? Took them both back and got a philips that worked great but when my computer unplugged itself, it crashed the device. Now no on function and restore will not work as the pc will not see player anymore. Nice devices! will try support from manufact. but tried resetting w/battery out etc,with no success. Suggest updating firmware as soon as connection is accepted to pc. Hope I helped.
Posted on Feb 04, 2007
Cant edit the songs, unable to view
Check if the songs you transferred are mp3 or wma or try another XP service pack ( You could just try it on another pc)
Jun 22, 2009 | SanDisk Sansa m240 MP3 Player
Mp3 is frozen after downloading a new song off of a website!!
let the battery die. hook it up via usb and reflash it using sansa firmware updater. it will erase everyting but at least it will start working again.
May 23, 2009 | SanDisk Sansa Fuze MP3 Player
The display screen is turning pink??
mine did that so i had 2 unscrew the back and remove the battery then when i had put it all back together it worked
Jun 15, 2008 | SanDisk Sansa e270 MP3 Player
Sandisk sansa mp3 2 gig pink player
i tell you connect to the computer your device
and right click on your device and format it
and refill the songs
Jun 08, 2008 | SanDisk Sansa Clip MP3 Player
Songs gone
try going to windows media player, updating your library, then going to the sandisk site, find the update dowload, run that then re- hook up your mp3 player to the computer!
May 10, 2008 | SanDisk Sansa e250 MP3 Player
Is my player messed up or is it napster
Need to keep your msuic svc subscription updated, and resync eveyr 30 days or more
Sep 20, 2007 | SanDisk Sansa e250 MP3 Player
Removing bad tracks
I beleive your player saves a lists as well as the song itself. the easiest way to fix it is to (if possible) use windows explorer, goto your player and look for a folder that says "albums" or "list", scroll thru and delete the folder of the songs that you have deleted.
Aug 15, 2007 | SanDisk Sansa e260 MP3 Player
Sansa is acting weird....
Well, you need to return it for a new one. If it has happened in so many few weeks, you need to. It sounds like you may have downloaded a virus. you are going to reboot it and or restart it, you have tried this so it sounds like it is just messed up. exchange it or send it in to get it reset. It will run you about $35. Thanks, Connie
Jun 24, 2007 | SanDisk Sansa e250 MP3 Player
Feb 01, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
41 people viewed this question
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
