Question about HP Officejet 4355 All-In-One InkJet Printer
Fax card of HP Officejet 4355 All-In-One InkJet burnt
Fax card burnt
Posted by nar123 on
Anonymous
I lost my driver.can anybody help me?
Posted on Apr 11, 2008
Fax machine not working on HP LaserJet M2727 nf
> Incoming & out going both are not working?> Check line is OK?> Remove left side cover
> Replace Fax card,P.No CB534-60117> Replace Formatter PCA P.No.CC370-60001 > Most of the cases found Fax card failure. see the snap shot of fax card.
Oct 13, 2011 | HP Laserjet M2727nf Multifunction Printer
Driver intex etrenet card
If you are looking for the LAN card drivers, follow the following steps:
1. Go to: http://www.intextechnologies.com/webpages/download-driver.aspx
2. Under the "Download Drivers" section, click "Lan Card (IT-584)".
3. Click on either "Win Vista" or "Win XP". This will start the download of your LAN card's drivers.
If you are looking for the fax/modem card drivers, follow the following steps:
2. Under the "Download Drivers" section, click "Fax Modem".
3. Find the type of your Fax/modem card, and click on it.
4. Click on the name of your operating system. This will start the download of the drivers for your Fax/modem card.
Jul 10, 2009 | D-Link DFE-530TX+ Ethernet ED100W Network...
Lan Card burnt
Not worth repairing
May 20, 2009 | Panasonic KX-FM181 Fax
I can not get the fax to work on our Kyocera Mita CS-2550
Double check with the fax card if its really connected, coz usually when you cannot access to register key this means your fax card is not recognized yet, just unplug the fax card and plug it again, and check the status.
make sure you plug the phone line where it says line not T1 ot T2
and to know if your line work, hit fax buttom and then look to the screen and touch onhook buttom, if you heard the phone hook sound this means is working fine, if not check the fax card.
Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Nov 18, 2008 | Kyocera Mita KM-2550 All-In-One Laser...
Faxing
Normal 0 Sending Fax Using Calling Card:
Load document in the ADF
Press [FAX]
Adjust settings for your documents as necessary
Press [Hook] Alternatively, you can lift the handset if one is connected to the machine.
Dial your calling card information responding to all calling card prompts on the fax key pad. After dialing the recipient’s number using the numeric keys or speed dialing, wait for the high-pitched fax signal.
When you hear a highpitched signal, press [Black} for black & white sending.. Hang up the handset if you used it.
Oct 18, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Fax 575
The black curly cord goes from the phone receiver (handset) to the first jack on the left side of the fax (the one closest to the handset that's marked with a phone symbol). The flat grey cord is the phone cord. It connects the wall jack to the fax machine's third jack (the one closest to the back of the machine that's marked with the word "LINE").
Sep 12, 2008 | Brother FAX-575 Plain Paper Thermal
When we copy on our 4750e fax it comes out with black page
Can you see light from the scanner unit with you make a copy or try to send out faxes? The bulb for the scanner may be burnt. You might be able to find a replacement bulb, search google or contact Brother.
Jun 16, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Using a calling card for a long distance fax
It will surely help if you are using a calling card that has a pinless dialing feature where you don't need to dial your pin. I use Onesuite.com calling card and it has that feature and sending a fax through regular fax machine is easier than having to dial your pin midpoint.
Apr 19, 2008 | HP Photosmart 2410 All-In-One InkJet...
Richo Aficio 5000L Fax - Fax Operation not working !!!!!!!
First, determine whether the telephone line is working properly. Remove the telephone line from the machine and replace with a test handset. Try calling the fax number and see if you get fax tones on the handset. If not, there is a problem with line switching. If you do get fax tones, then the machine is at fault. Now plug the line cord into the machine, check that it is in the correct input jack, as there may be unmarked jacks open on this machine. Check the display and see that it is ready.Is the machine trying to communicate with another fax number? If so, change the service station fax number to a machine that is close by.(User Tools 2 then immediately 1998 start within 3 secs. then 13 and change the number.) Try to send or receive a fax and observe there is or not 3 sheets of data sent to the machine you just programmed as the service machine.So then, is the machine configured with 1 or 2 modems? Determine that the problem happens with both modems. If so, the modem is not suspect. Now let me stress this, that if you are not a qualified Ricoh technician, do not attempt any further checks yourself.
Next, do a complete level 3 reset. Remember that the machine may be configured with a feature upgrade card which may contain 999 additional speed dial numbers. Do not remove this card yet. However, repeat the receive checks with the memory card removed. If there is no Feature upgrade card or a fax on demand card in the left hand slot, then check the contents of system switch 16. If this is set to 1. If so, then the machine will not work unless a ic or data copy tool is present in the slot. Repeat the tests. Power off and remove the memory card and the feature upgrade card. Power on. Set System switch 16 to 0 and repeat the tests.
Theres more tests, but I don't have the space to go through them all, the manual is 300 pages.
Jan 24, 2008 | Office Equipment & Supplies
HP Officejet 4355 All-In-One InkJet Printer Logo
61 people viewed this question
Ekse
Thomas F. Schneider
