2005 Cadillac CTS Logo
K
Keith Frank Posted on Apr 18, 2014
Replace cylinder 4 fuel ejector
The circuit on the #4 fuel ejector is open. My #4 cylinder is misfiring due to the circuit being open on the fuel ejector.
Brian Newland
Level 1:
  • Contributor 23 Answers
  • Posted on Apr 18, 2014
Brian Newland
Contributor
Level 1:
Answers
23
Questions
0
Helped
5267
Points
66
That means you need a new injector.
03 Nissan Altima showing codes P0304,P0102,P0154,P0113 what are they and how do i repair the problems.
Hi Chris.
p0304 = Number 4 Cylinder Misfire Detected
Faulty spark plug 4
Clogged or faulty fuel injector 4
Faulty ignition coil 4
Fuel injector 4 harness is open or shorted
Fuel injector 4 circuit poor electrical connection
Ignition coil 4 harness is open or shorted
Ignition coil 4 circuit poor electrical connection
Insufficient cylinder 4 compression
Incorrect fuel pressure
Intake air leak
The P0304 code means that the cylinder 4 is misfiring or is randomly misfiring. Start by checking for intake leaks an if no leaks are found the next step is to replace the spark plugs on cylinder 4.
p0102 = Mass or Volume Air Flow Circuit Low Input
Faulty mass air flow sensor
Intake air leaks
Dirty mass air flow sensor
Dirty mass air filter
Mass air flow sensor harness is open or shorted
Mass air flow sensor circuit poor electrical connection
Before replacing the mass air flow sensor, try replacing the air filter and cleaning the air flow sensor with low compress air or mass air flow sensor cleaner.
Reset code and drive vehicle.
If the code comes back, it may be necessary to replaced the mass air flow sensor.
p0154 = O2 Sensor Circuit No Activity Detected Sensor 1 Bank 2
Faulty Front Heated Oxygen Sensor Bank 2
Front Heated Oxygen Sensor Bank 2 harness is open or shorted
Front Heated Oxygen Sensor Bank 2 circuit poor electrical connection
Inappropriate fuel pressure
Faulty fuel injectors
Intake air leaks may be faulty
Exhaust gas leaks
Replacing the Front Heated Oxygen Sensor Bank 2 usually takes care of the problem.
p0113 = Intake Air Temperature Sensor Circuit High
Faulty Intake Air Temperature (IAT) sensor
Dirty air filter
Intake Air Temperature (IAT) sensor harness is open or shorted
Intake Air Temperature (IAT) sensor circuit poor electrical connection
The Intake Air Temperature (IAT) sensor is built into mass air flow sensor or in some vehicles mounted to the air filter duct housing. The sensor detects intake air temperature and transmits a signal to the Engine Control Module (ECM).The temperature sensing unit uses a thermistor which is sensitive to the change in temperature. Electrical resistance of the thermistor decreases in response to the temperature rise. The Intake Air Temperature signal is used as an input for various systems in the vehicle.
Hope this helps
FYT
http://www.autocodes.com/make/nissan
1helpful
My 2006 ford fusion sel v6 is having cylinder misfiring problems the codes it reads out are p0171 p0304 p0305 p0306 and p0300
p0171 is fuel injection system too lean - bank 1
possible causes
- Intake air leaks - Faulty front heated oxygen sensor - Ignition misfiring - Faulty fuel injectors - Exhaust gas leaks - Incorrect fuel pressure - Lack of fuel - Faulty Mass Air Flow (MAF) sensor - Incorrect Positive Crankcase Ventilation (PCV) hose connection
p0304 is cylinder 4 misfire detected.
possible causes
Faulty spark plug 4 - Clogged or faulty fuel injector 4 - Faulty ignition coil 4 - Fuel injector 4 harness is open or shorted - Fuel injector 4 circuit poor electrical connection - Ignition coil 4 harness is open or shorted - Ignition coil 4 circuit poor electrical connection - Insufficient cylinder 4 compression - Incorrect fuel pressure - Intake air leak
p0305 is same as above but cylinder 5.
p0306 is same as above but cylinder 6.
p0300 is random misfire detected
possible cause
Faulty spark plug (s) - Faulty ignition coil (s) - Clogged or faulty fuel injector (s) - Intake air leak - Fuel injectors harness is open or shorted - Fuel Injectors circuit poor electrical connection - Ignition coils harness is open or shorted - Ignition coils circuit poor electrical connection - Insufficient cylinders compression - Incorrect fuel pressure
I have a Saab with a service code P0304 I looked into it usually bad ignition coil...I replaced the coil but No go, any ideas?
P0304 code means - Cylinder 4 Misfire detected.
Possible causes are:
- Faulty spark plug 4
- Intake air leak
1helpful
How to fix a code P0304
The P0304 code means that the cylinder 4 is misfiring or is randomly misfiring. Start by checking for intake leaks an if no leaks are found the next step is to replace the spark plugs on cylinder 4. If the problem persist more tests needs to be done to diagnose problem, see "Possible Causes"
- Intake air leak
most likely change your spark plugs these should be done every 60,000 km
2answers
I have a 2002 Jaguar X-type. The check engine light came on and it has been acting jumpy/shaky. I recently took it to be diagnosed and the codes I recieved back were P1314, P1316, P1111, and P0302..What do...
All fault codes can be checked out at http://www.bluejag.co.uk but here are the results for some of yours. You can ignor P1111. Looks like a faulty plug or coil pack cylinder 2
Fault Code:- P1314 Indicates a Power-train fault
The fault is generally due to a problem in the Ignition or Misfire area
Fault Description: Misfire rate catalyst damage -bank 2 NOTE: This DTC will flag only when accompanied by an individual cylinder misfire DTC: P0300 - P0306
Action of ECM:- ECM Default:- Maximum engine speed reduced
After clearing the DTC, complete the Misfire monitor drive cycle
Check for a reoccurrence of fault DTC.
Possible Fault:- Cylinder compression low Worn camshaft / broken valve spring(s) Fuel delivery pressure (low / high) Fuel injector(s) restricted / leaking Fuel injector(s) continuously open Fuel contamination Fuel injector circuit fault(s) (Injector DTCs also flagged) Spark plug failure / fouled / incorrect gap ECM to ignition coil primary circuit fault (Cylinder misfire detected DTC also flagged) Ignition coil failure
Fault Code:- P1316 Indicates a Power-train fault
Fault Description: Misfire excess emission NOTE: This DTC will flag only when accompanied by an individual cylinder misfire DTC: P0300 - P0306
Action of ECM:- none
Fault Code:-
P0302 Indicates a Power-train fault
Fault Description: Misfire detected ?€" cylinder 2
Possible Fault:- Refer to P0300 Possible Causes
I have a 2008 dodge avenger se and my engine light is on and was flashing before. when it is in drive or park it turns off when i stop. i took it to auto zone and the told me that cylinder 3 and 4 misfire...
Possible causes:
Faulty spark plug
Fuel injector
Harness is open or shorted
Fuel injector circuit has poor electrical connection
Ignition coil harness is open or shorted
Ignition coil circuit poor electrical connection
Insufficient cylinder compression
Intake air leak
The P0304 code means that the cylinder 4 is misfiring or is randomly misfiring. Start by checking for intake leaks and if no leaks are found the next step is to replace the spark plugs on cylinder 4.
4helpful
2answers
Hi my 2006 cadillac cts has error codes po 300 303 305 343 347 368 392 and 496 can u tell me what they are or a website to find out thank u
P0300 is multiple engine misfire detected
P0303 is misfire in cylinder 3
P0305 is misfire in cylinder 5
P0343 is camshaft position sensor A (bank 1)
P0347 is camshaft position sensor A (bank 2)
P0368 is camshaft position sensor B (bank 1)
P0392 is camshaft position sensor B (bank2)
P0496 is EVAP Canister Purge System High Purge Flow
Crossfire misfire 4/5
DTC codes that will trigger P0304 Misfire Detected Cylinder #4 & P0305 Misfire Detected Cylinder #5.
Possible Causes:
- Improper spark plug at cylinder
- Insufficient compression at cylinder
- The injector circuit is open or shorted at cylinder
- Fuel injector may be faulty
Possible Solutions:
- Perform Injector Service
- Replace Spark Plug
- Replace Injector
- Replace Ignition Coil
1helpful
2003 Hyundai Sonata with 4 cyl. PO301 error code. Have replaced spark plugs, wires, coil packs, and mass air flow sensor. Replaced air filter due to heavy gas smell. Car was starting after tapping gas 3...
P0301 - Cylinder 1 Misfire Detected.
Possible Causes:
- Improper spark plug at cylinder #1
- Insufficient compression at cylinder #1
- The injector circuit is open or shorted at cylinder #1
- Fuel injector #1 may be faulty
- Intake air leak at cylinder
Possible Solutions:
- Replaced Spark Plug #1
- Replaced Injector #1
- Replaced Ignition Coil #1
Being you have a heavy gas smell I would look into the injectors. If injector #1 is over producing it can cause a misfire. Test your compression and fuel pressure.
12helpful
3answers
CODES-PO301-PO303-PO316- CHANGED PLUGS & WIRES. STILL MISS ON START UP, GOES AWAY MOST OF THE TIME ABOVE 1000 R.P.M
Causes:
- Intake air leak
Solutions:
P0303 - Cylinder 3 Misfire Detected.
Follow info from P0301.
P0316 - Misfire Occurred In The First 1,000 Engine Revolutions.
Causes:
- Damaged CKP sensor.
- Ignition System.
- Fuel Injectors
- Running out of fuel
- Fuel Quality
- Base engine
- Damaged Powertrain Control Module
Solutions:
Usually the P0316 is combine with a P03XX codes. The P03XX code indicates in which cylinder the misfire occurred.
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
