Question about Samsung YP-K5 MP3 Player
Error code COOD11B1
I have windows home premium with windows media player 11 integrated. Here is my problem: when I go to download music from bell sympatico music store, to wich I subscribed at $12.00 a month for unlimited downloads, unto my MP 3 Samsung YP-K5AJB player, the music will not download and the error code COOD11B1 appears. Can you please help me. In addition, it is impossible for me to download Media Studio since it is not compatible with Windows Vista. When I try do to so, a window pops up indicating that Media Studio can only be downloaded through Windows XP. Please help.
Thank you.
Posted by jojovava on
  • jojovava Nov 07, 2007
    It is only from Sympatico I don't know what to do, Please help me. As I told you I have Windows Vista Home Premium, could that be the problem???
  • ghggh Jun 29, 2008
    same problem
Anonymous
Is that problem only with the music you downloaded from Sympatio or is that with all youre music,
If it is with only with the musci from simpatio it may be right protected or something that wont let it
Posted on Nov 03, 2007
  • Anonymous Nov 10, 2007
    probably you should try converting the audio formats to a diffrent format, the error code is something that mainly affects windows media player files dont know why,
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
How do you download music
Hi stetsoncowgi...
Downloading Music to MP3 Player
1...You must download and install Windows Media Player 11 on your computer.
NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11.
If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10.
2...After you have downloaded and installed Media Player on your computer.
3...Open Media Player on your computer.
4...Install all your music into Media Player that you want to install on your MP3 player.
5...Plug in your MP3 player to the computer using your Data/Sync cord, be sure that Windows Media Player is on.
6...Media player should recognize the MP3 player and sync with it.
7...After it is sync'ed with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player.
Please take time to rate me
Aug 23, 2011 | Coby Audio Players & Recorders
I don't no how to download music videos to my mp4
Hi
Free Answer...Please take time to rate me
Jul 31, 2011 | Audio Players & Recorders
How do I put music onto my new Innovatek premium Edition mp3
Hi taylor91...
Jun 02, 2011 | Audio Players & Recorders
Cannot play any music
This looks like a Windows Media player error code. If so, try this.
The following are the steps that you should perform if your player is not receiving streams:
Open Windows Media Player.
If you don't see the menu selections File View Play Tools Help at the top of the player, RIGHT-click on the very top of the player and select Show Menu Bar.
Select Tools and then Options and the Network tab.
Under the Streaming Protocols section, be sure that ONLY TCP and HTTP are selected.
Select the Performance tab.
In the Connection Speed section, select Detect Connection speed (recommended).
Select the Player tab.
In the Automatic Updates section, be sure that Download Codecs Automatically is checked.
Be sure that Connect to the Internet (overrides all other commands) is checked.
Select the File Types tab.
Click the Select All button.
Click OK and totally close the player and try connecting again.
Aug 21, 2009 | Computers & Internet
My windows have a error call COOD11B1
it is a media player error
(try downloading the latest media player)
hope this helps :-)
Sep 03, 2008 | Computers & Internet
Error code COOD11B1 in windows media player 11
This error code is to with DRM (digital rights management) within WMP.
The only solution i could find was from Microsoft themselves.
Have a read of this page and give it a go...
http://support.microsoft.com/kb/920075
Where is asks you to start IE, it has to be IE and no other browser as for some reason this update only works if you use IE.
Hope this helps
Aug 15, 2008 | Computers & Internet
Samsung YP-K5 MP3 Player Logo
166 people viewed this question
Top Samsung Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
