Question about E-Machines T2682 (000002965) PC Desktop
E-Machine T2862 Will Not Power UP
I have a problem with my daughters eMachines 2862 Desktop. Nothing happens when you press the power button on the front. The machine was working fine and then the next time she came to switch it on nothing happened, no fans no power light. I have installed a new replacement power supply, because I read that the eMachines P.S were prone to failure but it is still the same. There is a tiny green led that lights up on the motherboard when I plug the power cord in but thats it. It's not the power switch as I have I have removed the switch and connected the wires. Is there anything to reset, like a thermal overload or reset switch? I'm totally lost
Can anyone help.
Thanks
JWH
Posted by imagemaker on
  • 8 more comments
  • imagemaker Nov 04, 2007
    Thanks Benimur but yes I did just short them momentarily, without success, so unfortunately the computer is still not working.
    Best Regards,
    JWH
  • vmajewsk Nov 20, 2007
    I have the same pc and i think the mobo tanked!
  • Anonymous Mar 31, 2008
    the machine was making a lot of noise...not sure if it was fan type noice, or disk, cd/dvd spinning type noise...at any rate, the noise seemed louder than normal activity, so I shut the pc down (from the shut down on the win xp menu)...the next day, when we tried to power it up, nothing
    also, I disconnected the 3 leads from the front panel and now can't figure out where they plug in on that socket...anyone know which pair of connectors you plug those 3 leads in on?
    tia
  • Anonymous Jun 23, 2008
    Same problem
  • drdavo Aug 24, 2008
    I am having the same exact problem. The old ps did not give me a green light on the mb, the new ps does, but nothing else. I chatted with emachine support but they were no help.
  • Anonymous Sep 27, 2008
    've the same problem, unfortunately, I disconnected the 3-plug
    connectors to the on/off switch, thinking they were a single plug. Now
    I don't know quite how to re-plug them.
    The three color codes
    are black-white blue-white and red-white. I have the motherboard guide,
    but I would appreciate anyone's help reconnecting the 3-plug set
    correctly.
  • Anonymous Oct 06, 2008
    I resolved my problem by buying a $174 Dell slim desktop and and external IDE container.
    I found the jumper connections online, but it failed to help and it just wasn't worth the bother. I've just seen too many similar problems with the e-machine to warrant trying to fix the thing.
    I can't attach the html here, but e-machines support put me onto a web-page titled: D845GVSR_jumpers.html which showed the jumper connections.
  • simon_128 Apr 21, 2009
    I got the same problem that I had been fixing for almost a year and a half.
    I'm considering getting a replacement motherboard for my eMachines T2862 desktop machine. Any suggestions?
  • onecandyx Apr 22, 2009
    My computer turned off one day by itself.the power butoon was still on but nothing was showing on the screen.I turned the machine off and it hasnt been able to turn back on since.I was told it is the motherboard but i dont belive it is.
  • kitkatr May 20, 2009
    I have the same problem where my daughter's T2862 does not power up. I have no technical skills with computers. The discussions posted seem to require some rather sohisticated skills (from my perspective). What can a no-skill person do to power our computer up? Thanks.
Anonymous
Regarding the power + power LED +HDD LED connections, if you haven't tossed the unit yet -- looking straight down with the box laying on side (e.g. CPU fan blades pointed straight at you) -- GreenWhite + BlackWhite (start with left pin, row nearest top of case) RedWhite (left two pins, row nearest bottom of case)
I have this same box doing nothing with new PSU, whether bare mobo or with components, and trying to short PWR pins manually. Oh well, emachines are basically disposable, much to the chagrin of Mother Earth...
Posted on Dec 07, 2008
Anonymous
I've the same problem, unfortunately, I disconnected the 3-plug connectors to the on/off switch, thinking they were a single plug. Now I don't know quite how to re-plug them.
The three color codes are black-white blue-white and red-white. I have the motherboard guide, but I would appreciate anyone's help reconnecting the 3-plug set correctly.
Posted on Sep 27, 2008
    correctly.
    I resolved my problem by buying a $174 Dell slim desktop and and external IDE enclosure.
    (on line) with the e-machine to warrant trying to fix the thing.
    connections.
Larry Browning
    Problem Solver:
  • 6 Answers
It's probably the motherboard they are notoriously known to be weak. I've got myself into a situation where I have to replace one I will let you know what will slip into there with no case modification.
Posted on Feb 19, 2011
  • Larry Browning Feb 19, 2011
    Found a replacement at http://www.cputopia.com/emachines-mother... they don't rape you too badly $129. Also when I was inspecting the system the power supply HV transistors looked bad don't know what thats about so I replaced that for my client too (worth checking out before powering up) Hope that helps
linuxskynyrd
The problem may possibly be one, (or more) of the capacitors on the board. Check to see if any are "buldging" on top. They should be flat but if any are "rounded", this is most likely the issue.
Ray
Posted on Jul 10, 2009
Anonymous
It seems from googling that eMachines are well known for this problem, the power supply goes out and when it does it takes the mobo with it. I've had 2 eMachines (one mine, one a friends) go out the same way.
Posted on Oct 04, 2008
Louie Role
    Brigadier General:
  • 6,966 Answers
When you posted "It's not the power switch as I have I have removed the switch and connected the wires.", do you mean that you twisted the wire together? If yes, try just momentary touching them together. Most PC switches work on a push button momentary on system. Permanently joined together will not activate the PSU.
Otherwise, pls post back.
Good luck and kind regards.
Posted on Nov 02, 2007
  • Louie  Role
    Louie Role Nov 05, 2007
    Hi again,
    Since there is a "tiny green led that lights up", we can safely assume that the power supply is OK. One of its features is to auto-shutdown in the event of a power related problem such as a high current demand by the motherboard, HD and other devices.
    Perhaps you can try removing all the power connectors to all devices except the motherboard (HD, CD, FDD) and try if the PC will power up. If it does, you can try plugging them back one by one and determine which causes power up failure. If not, it may be that you have a faulty motherboard.
    Another that you can check is the fan itself of the CPU. Verify that it can rotate freely and not stuck up. Some models will not go through the power up if the fan is not rotating.
    Incidentally your query as to a reset in your initial post, the only available reset on the motherboard is the CMOS/BIOS. It is a 3 pin/terminal with a jumper on 2 normally located very near the Lithium battery. Moving the jumper to the opposite pairing for a couple of seconds would reset the CMOS/BIOS of the motherboard to default. Thereafter, you need to move the jumper back to its original position.
Anonymous
    Problem Solver:
  • 4 Answers
The "solution" for me was moving the hdd to another unit I bought on ebay for $90...a dell optiplex with a ~3ghz p4 and a half a gig of memory...you can still use the xp os (you just need to go through the grief of working with ms support in india)
Posted on Dec 13, 2008
2 Related Answers
paul proctor
  • 4102 Answers
SOURCE: eMachine 2862 Desktop Dead On Power-Up
check all the leads to the hard drive and check that the fan starts spinning when you switch it on if it dont start then the problem is the switch these do often go and can be easily replaced and they are not expensive i had the same problem and found that it was just the switch hope this solves your problem for you you can bypass the swith so that the computer comes on when you turn the plug on but when you shut down the computer this shuts everything down but the switches are cheap enough to buy if you have changed the power pack then the only thing it can be is switch .................................
Posted on Oct 31, 2007
night71
Lyle Siemens
  • 328 Answers
SOURCE: E-Machines 2862 Dead On Power-Up
I believe that the front button is not connecting to the switch for the power supply. Also make sure all internal connections are secure. Sometimes the button breaks from behind so that it cannot contact the switch. Let me know if it helps. There are other solutions if you tried this one first.
Posted on Nov 01, 2007
The power button on my computer won't turn on the computer
if no any power indicator at the front and also the fan at the power supply as will as in the mother board, it was a power supply failure.
Nov 25, 2012 | eMachines EL133105 Desktop Computer with...
EMachine 2862 Desktop Dead On Power-Up
Oct 31, 2007 | E-Machines T2682 (000002965) PC Desktop
My emachine won't power up.
Power is not working.replace the power cord and check if it stays the same then your power box is not working.
Jul 16, 2012 | E-Machines eMachines Desktop PC
My e-machine (T2332? or T2382? Can't remember for sure) about 5 years old was working fine yesterday. Then today, I go to turn it on and I press the power button on the front and the light just...
I would request you to check for the power calbe. Try and change the power cable and check if that works and make sure there is no continous beep on the machine as it would be a issue with RAM or hard drive.
Hope this helps you. I would request you to give a feedback on this solution as it would be appreciated.
Thank you.
Gowtam R
Jun 24, 2011 | E-Machines eMachines Desktop PC
I cannot boot up the computer. When I push the front power button, nothing happens. When I flip the switch on the back, or unplug it for 30 secs and plug it back in, the fan starts up and a yellow light...
I had this happen to my emachines T1842 about a year ago. I replaced the power supply and it worked fine. It was about 25 bucks but fixed my problem. Make sure the red switch on the back hasnt been messed with. it should be on 115. If you have moved it, it may have blown a fuse inside the power supply.
Feb 04, 2010 | E-Machines eMachines Desktop PC
Emachine T3624 will not power up
Emachines are notorious for having faulty power supplies. If your lucky you just need to replace the power supply. I've seen a lot of them where the power supply also fried the motherboard.
Please don't forget to rate this solution.
Jun 15, 2009 | E-Machines T2984 PC Desktop
Emachine desktop power switch is shot
I would still try to replace the power supply first,before replacing the motherboard.In 80% cases that you are describing it is the power supply.
Hope this helps
Mar 24, 2008 | E-Machines eMachines Desktop PC
Power switch does not turn computer on
If the switch has a (O) and (I) on it ,the (I) should be pushed in.
Jan 10, 2008 | E-Machines eMachines Desktop PC
Nov 01, 2007 | E-Machines T2682 (000002965) PC Desktop
E-Machines T2682 (000002965) PC Desktop Logo
3,749 people viewed this question
Top E-Machines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
efs_perpends
efs_perpends
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
