Question about Hotpoint Refrigerators
Hotpoint ff73 fridge section not functioning
Tried switching off for about 10 hours, switched back on and all was fine for a few days, now it is playing up again. I cleaned out the section behind the lower grille, the fan is running, but intermittent, sometimes when i operate the door switch it is blowing then it stops and starts again. Any pointers as to what to look at next please?
David Emmel
    Sergeant:
  • 295 Answers
Model no. returns no information.
Sounds like you have a defrost problem. Once symptoms show up, the failure probably occurred 1-2 weeks prior, resulting in frost accumulating in the freezer. Turning it off will allow it to manually defrost and will work ok for another 2-3 weeks.
There are 3 components that make up the defrost system.
1. Defrost timer
2.Defrost terminating thermostat
3.Defrost heater
You will have to replace all 3 components unless you can determine what's at fault
https://www.repairclinic.com/ for more help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Posted on Oct 16, 2017
5 Related Answers
Anonymous
  • 290 Answers
SOURCE: Freezer works fine...refrigerator section
Have you noticed more frost in the freezer than usual? It sounds like you may have moisture building up and freezing around evaporator fan. The fan blade hitting ice will cause the buzzing until it stops it completely or the evaporator clogs with frost and blocks airflow. If you have frost on food in freezer, check the door seals and make sure nothing is keeping doors from closing completely if you release them about 6" from cabinet.
Posted on Oct 07, 2007
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: Bottom freezer works fine....upper refrigerator has stopped working...
Hard to say with this description of the problem but sounds like your having a problem with the compressor starting consistantly. If it is a tecumpseh compressor it is most likely a problem. Take the back off the refrigerator and there will be sticker on the compressor that will tell what kind it is. Should say either embraco(the good kind) or will have a blue picture of an indian head (tecumpseh).
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: freezer section not working
You can start with replacing the start capacitor and relay to see if the compressor will run again, but you have about a 50 -50 chance that the compressor has gone bad and will need to be replaced....
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Asker's Testimonial " Very helpful. Will give it a try and let you know outcome. Thanks!!!
Posted on Apr 08, 2010
jimmy wong
  • 135 Answers
SOURCE: KIC 230L double door fridge
IT HAS ONE YEAR WARRENTY.CAAL THE COMPANY
Posted on Jan 10, 2011
walterkunesk
Wally Bald Guy
  • 683 Answers
SOURCE: My hoover hfa29k fridge freezer originally started
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
Try this and let me know.
Posted on Feb 22, 2011
Where can I get a repair manual for a Hotpoint Fridge
First of all, the model number you gave is not complete. But check you defrost system in the freezer, when the refer section stops cooling, your evaporator in the freezer is possibly full of ice and the fan won't move air through ice. When the refer sections fails to cool, check for a fan in the freezer. If it works, you have a defrost problem and is occurs every 3 - 5 days. The unit should defrost once or twice a day. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 20, 2016 | Hotpoint Refrigerators
Hotpoint fridge clicks before starting
You have a possible compressor relay going bad or something like low house power could cause that. Also the mother board could be going bad without seeing any problem. Electronic boards sometimes go bad without being able to actually see it. The compressor part of the board will sometimes burn a spot on the mother board but can only be see on the back solder side.
Apr 07, 2015 | Hotpoint Refrigerators
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
Why is Fridge not cooling well?
The part number you need is going to be WR09X10050. This is for the damper assembly, but while you are at it change out part number WR55X10150. this is the part that controls the damper and more than likely if one fails the other will be soon to follow
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 05, 2012 | Hotpoint Refrigerators
Fridge part working freezer not
The fridge is just the end of the freezer evaporator. If the freezer isn't cold inside, check the rear panel. It is probably frozen solid with no air getting through. Switch off, leave doors open for 24 hours and be prepared for lots of water to come out. Clean the condenser and make sure the fan inside is ok. Reset the thermostat to middle of the range and be sure to come back to tell us how you get on.
May 17, 2012 | Hotpoint Refrigerators
Freezer working but not fridge
most likely a defrosting problem in the form of a bad defrost timer or element in a unit that age. One way to prove it is a defrosting problem is to remove the contents of the freezer section un plug the unit and place a fan on it for about 2 hours. This will make a water mess so be prepaired for it. Then plug it back in and load it up with the frozen food you removed... If it works fine for a few days then you have a defrost problem. After the test run here .. if it is in good shape still I would have have it serviced.
Jan 16, 2010 | Refrigerators
Refridgerator beeps and upper section not working
First, the Samsung Refrigerator is the only fridge that has one compressor, but two different evaporators to operate the freezer and the refrigerator separately. Thus, you can have the bottom freezer working fine, while the fridge part will not.
The reason your fridge is not working is probably a faulty door switch in the refrigerator. The switch is malfunctioning, telling the computer that the door is open. Therefore you hear the door alarm go off in intervals, even though the door is actually closed. If the computer registers an open door, it will not pump cool air into the refrigerator, as that would be a waste of energy. All you need to do is replace the door switch. Until you get a new one, you can temporarily fix your fridge by simply removing the old switch altogether. You will not have any light in the fridge, however, it will cool again just fine until you are able to install the new switch (a simple plug-in contraption, by the way).
Hope this helps.
May 28, 2009 | Samsung RB2155SH Bottom Freezer...
Hotpoint FFS70 fridge problem with draws.
Not sure which drawers you are talking about BUT have you tried switching over the two crisper drawers? They are not interchangeable, i.e. there is only one way the will fit inside the fridge.
Jun 12, 2008 | Hotpoint FFS70 Bottom Freezer Refrigerator
Hotpoint ultima fridge freezer
It's just simple.Keep the refrigerator open for few days with power on.After when the electricity bill comes,eveerything will be cooled.
May 28, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
55 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
