2007 Kia Rondo Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Brown
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Yellow
Car Stereo Dimmer Wire: Black/Orange
Car Stereo Antenna Trigger Wire: Blue
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Orange
Right Front Speaker Positive Wire (+): Brown
Right Front Speaker Negative Wire (-): White
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Blue
Right Rear Speaker Positive Wire (+): Black
Right Rear Speaker Negative Wire (-): Yellow
SOURCE: 2007 Kia rondo interior lights stay on when headlights turned on
I had the same problem for months. Finally took it to the dealer. The first time, they diagnosed is as a short in the rear interior bulb, and put in a new bulb. Got it home and still had the same problem.
The second time in, they figured things out. On the dash to the left of the steering wheel is a knob that controls the brightness of the dash lights. But, if this knob is all the way on, it turns on the interior lights and keeps them on. Just had to turn this knob down, and the problem was solved!
SOURCE: change front rotors kia rondo 2007
Remove the tire, remove the brake calipers, 2 bolts on back side of rotor, remove the carter pin that retains the bolt position if equiped, remove the center nut. When you pull the rotor off watch for a set of bearings to drop out. To install the new rotor reverse the process.
SOURCE: toyota tacoma 2007 stereo wiring
Radio 12v blue/yellow + radio harness
Radio Ground brown - radio harness
Radio Ignition gray + radio harness
Radio Illumination green + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- pink - purple +,- radio harness or amplifier
RF Speaker +/- lt. green - blue +,- radio harness or amplifier
LR Speaker +/- black - yellow +,- radio harness or amplifier
RR Speaker +/- red - white +,- radio harness or amplifier
Notes: If equipped, the amplifier is on the passenger side rear cabin wall.
SOURCE: engine light came on kia 2007 rondo
you need to have the code read to see what it is most auto parts store can do that for free that will help use tell you what it is
SOURCE: were is the fuel filter
IT IS INSIDE THE FUEL TANK . IT IS MADE INSIDE THE FUEL PUMP IT IS SERVIECABLE AND RECOMMENDED EVERY 30K . THERE IS A ACCESS TO THE TANK UNDER THE SEAT THERE IS A FEW SCREWS THAT HOLD IT A COVER DOWN REMOVE THIS AND YOU CAN ACCESS .
REOMOVE FUEL PUMP AND TAKE APART THE ACTUAL PUMP SEATS INSIDE THE FILTER .IF YOU TRY TO DO IT YOURSELT BE SURE NOT TO FORGET ANY O RINGS THEY TEND TO STAY IN THE OLD FILTER WHEN REPLACING AND IF YOU DONT SWAP OVER THE VEHICLE WILL NOT START
