Unplugged the power cable from the modem to reset because internet had no connection, when plugging the power back on, there was no power light on and the modem was not responding with any light indications, the electricity is working with other outlets...is the problem could be with the power cable or the modem just died??
SOURCE: Re-starting a ARRIS modem after a loss of power
You can try doing a "Hard reset" on the modem but it looks like you've tried most combinations. To do the hard reset: - unplug the coax cable from the back of the modem - Push and hold the "reset" button in for 15 seconds - Allow the modem 30 seconds to reinitialize and then plug the coax cable back in. Within 10minutes you should have activity back. If not, the modem needs to be replaced. I know you may have tried something similar to this but I'm hoping this may help.
Posted on Aug 13, 2007
SOURCE: Motorola SB4200 IP address
192.168.100.1 this is the default IP adress
Posted on Feb 03, 2009
SOURCE: 'How to fix flashing Power light on modem SB5100?
Check with your server.The registration details have been deleted.
Posted on Feb 10, 2009
SOURCE: Router cannot connect to the internet.
Turn everything off:
Cable modem unplug the power to the modem if it has a battery remove it.
Router unplug the power to the router
Shutdown any and all computers connected to the router
Turn everything on in this order:
Cable modem wait until all the lights are on but the internet act light
Router wait until the lights goes through it's test cycle and the internet light (wan) is on.
Boot up the computers one at a time after the first computer is fully loaded go to the next computer
Hope this helps
Terry
Posted on Feb 27, 2009
SOURCE: sb4200 modem not working
The only time you need software for a Motorola SB4200 is if you are using USB. If you use ethernet then it is simply plug and play, no drivers required.
The USB Drivers are here.
http://broadband.motorola.com/consumers/products/SB4200/downloads/v2.4.5_WHQL_Drivers.exe
Good Luck.
Hope this helps.
Please Rate
Posted on Apr 10, 2009
