I have a eclispe ch5061 6-disc changer with my 3422 reciever, the changer ejects and inserts cds okay but will not play when inserted in the cd changer. code info-3 shows on display of the 3422. what is the problem?
SOURCE: Not Playing CD's
info 3 means the radio can't read the disc as in the disc is dirty or damaged. More than likely it's not the disc, but the laser is failing. Time for a professional cleaning or replace the deck.
SOURCE: After having my vehicle repaired
This main unit is equipped with ESN (ECLIPSE Security Network). A music CD (Key CD) which has been registered in the main unit, is necessary for ESN. Without it, none of the functions will operate, even when the battery is reconnected after it has been disconnected for maintenance, or the ignition switch is turned to ACC or ON after it has been turned to OFF. ESN can be set or cancelled using any of the following methods: Key CD security You can register a music CD in the main unit as the "Key CD" to be used to set or cancel the security settings.
