Anonymous Posted on Dec 21, 2017
DVD player will not read disc
DVD surround sound player makes screeching and squealing noises while searching for disc. Seems as though it starts and stops, speeds up and slows down etc until it finally gives up and says no disc. It does this on all discs. I have tried disc cleaning disc but it doesn't help or it simply can't find it either.
degroot2940
Level 2:
Habit-Forming:
Scholar:
  • Expert 63 Answers
  • Posted on Dec 23, 2017
degroot2940
Expert
Level 2:
Habit-Forming:
Scholar:
Answers
63
Questions
0
Helped
20827
Points
160
Ouch! Sounds like the optical read head is miscalibrated and the player has issues finding the index track on the disc to load It correctly. Not sure about the squealing / screeching .. that could be a mechanical problem but the speed up and slow down are part of the read/ loading process
Larry
Level 3:
  • Pioneer Master 5,042 Answers
Larry
Pioneer Master
Level 3:
Answers
5042
Questions
Helped
1239457
Points
18413
It sounds like its not reading the disc, most the time that is caused by a bad processor and that isn't something you can fix yourself
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Oct 23, 2006
SOURCE: will not read disc & lots of motor noise
Your problem is a common one. The spindle motor is going bad or is bad, and/or you need to clean the laser lens. The only way to fix this would be to take out the unit and hook it up to a test harness. If you do not have a test harness you will need to seek out an authorized repair depot to do this for you. good Luck Ps Please dont forget to rate this thread.
hogan doan
hogan doan
  • 227 Answers
  • Posted on Apr 14, 2008
SOURCE: AVIC-N1 "disc read error"
The laser eye need to be re-align or clean up. If you are technical incline, then open it up and clean the laser eye and turn the mounting allen wrench nuts up a bit. If not have someone who knows do it. 'Cause there are alot of things can pop out of place when you opened it. Goodluck.
Anonymous
  • 1512 Answers
  • Posted on Dec 10, 2008
SOURCE: CD Payer PD-M426. When cartridge
Hi Peter,
First thing to ask you to check is that the discs have been inserted into the cartridge the correct way... that is writing facing down. Check that first and let me know how you get on. Happy to work through it with you.
regards
robotek
Anonymous
  • Posted on Dec 20, 2008
SOURCE: Won't read discs
Discs Must Be Loaded Label Side Down.
hogan doan
hogan doan
  • 227 Answers
  • Posted on Jan 21, 2009
SOURCE: Disc reading error
Hi, please browse through my solutions. You will find your answer there. Good luck.
1helpful
Crysler sebring jx 1996 makes grinding noise
Grinding or screeching? screeching is the belt. Even though you changed it something is wrong. try belt dressing. If that works and you put a new belt on, then the tensioner pulley may be bad. Not a big deal to change but it's function is to keep the belt tight so it doesn't squeal.
When I watch tv, I get a squealing noise, but when I watch a dvd, I don't get the squealing through the surround sound, also when I listen to a dvd through the surround sound I don't get the s
R U getting 'feedback'?i.e. if the speakers on the TV and your external speakers are pushing the same 'sound' towards each other there could be feedback.
DVDs/CDs are NOT being recognized in the player.
Yes or you could use a seperate dvd player,probably cheaper than having it serviced
so your disk might not be good go and change
Dvds makes a low screeching noise and then player says "no disc"
Hi
try to replace the flex ribbon wire first then test run. let me know what happen
Thanks!
1helpful
"no disc" error message
Did this problem just start? It may be due to the lens no longer reading the disc. Try a lens cleaner. If your lens went south, it usually is paired with a clicking noise or/and the combination of a no disc/disc error message. I would also recommend staying away from Polaroid dvd players and tv's in the future. They have a habit of not making parts available, especially after the warranty.
2helpful
DVD player and receiver will not play a dvd in surround sound ?
The dvd player is responsible for reading the surround sound track, and sending it to the receiver. First make sure you are playing the surround sound track on the dvd, many have a stereo track too. Next, try another dvd and see if you can play surround sound on that one. If you can't play surround on ANY dvd I would start looking at the audio connection from dvd to receiver. Are you using an optical cable? Red, white, and yellow RCA cables? Optical will transmit any sound over only one cable, RCA cables need one cable for each channel (LF, C, RF, LR, RR, sub.) If your connections are correct, is the receiver set to play a surround sound track? Is it set in 2 channel mode?
Spindle makes sounds and seems to grind and unable to read discs
i did notice inthese models there is a ribbon and for some reason the ribbon will hit the dvd making a noise..push it down it will scrach your dvd
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
