Question about Mitsubishi WS-55513 55" Rear Projection HDTV
My 2001Mitsubishi 1080 hd Won't come on
When I turn on my 1080 hd the green light comes on for maybe 2 seconds and clicks off. I've tried pressing input/menu and got 2 series of 2 flashes. I tried leaving it unplugged for 4 hrs and it still won't come on. Anything else I can try before calling a repair person? If not any idea of what kind of repair cost I am facing?
Thanks
Ron
Posted by RJC2007 on
  • 2 more comments
  • runnyman Nov 09, 2007
    my 1080 wont turn on. green light keeps flashing. Tried resest procedure green light will not go off.
  • Anonymous Dec 08, 2007
    The TV has been flicking for almost a week and wont come on.
  • bgayler Sep 01, 2008
    My 2002 model HD1080 65" has the same problem. We donated it to our church and it worked fine last week now when you try to turn it on with power switch ot the remote the green power light come on for a few seconds then goes off. You can hear a soft clicking sound as it comes on and also as it goes off.
  • dennisk31 Sep 10, 2008
    When I try to turn on my 42" the green light goes on for a couple seconds and then off, I tried to unplug it and still the same thing The light is on the timer label? anything I can try?
    Dennis
Vista Electronics
    Genius:
  • 1,694 Answers
Most Mits. models like yours will need a DM module repair or
replacement----either way, about 600.00.....T.
Posted on Nov 05, 2007
Mitsubishi medallion hd 1080
I would try the reset button in the front. Unplug the set push the reset and plug it back in.
Mar 27, 2014 | Televison & Video
Every time I turn my HD 1080 series Mitsubishi on 2 1/2 seconds later it turns off by itself
ok, a model number would be helpful but:
when set turns off and green power light goes out: on the front of the set press and hold both the menu and input (device) buttons at the same time for at least five seconds and let both go.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it for a total of 5 times.
This is the error code and indicates where the problem may be---let me know what code you find and I will tell you what it means.
SD TECH
Apr 28, 2012 | Televison & Video
Have Hd 1080 series tv model # vs-50111 tv will not turn on. When you try to turn it on green light stays on for 3 seconds then nothing.
it may or may not have the self check but try this:
When green light comes on and goes off ON THE FRONT OF THE SET press and hold the menu and input buttons at same time for 5 seconds or more and release both.
Power light should blink a two digit error code like 2 blinks, 2 blinks and pause--repeat it several times--all their sets after 1999 have this feature.
If yours does not someone has to go inside and measure voltages etc to find problem---a lot of the older ones develop broken solder connections and the chassis would have to be examined for that.
SD TECH
Apr 22, 2012 | Mitsubishi Televison & Video
Mitsubishi big screen HD 1080 series model WS-55809. it switched off one day. and when i turn it back on it switches right back off. red light in front. what part do i need to fix it/
That model does not have a red light---Green.
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
Mar 31, 2012 | Mitsubishi WS-55809 55" Rear Projection...
Older medallion 55" 1080...switched itself
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "input" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
May 14, 2011 | Mitsubishi WS-65413 65" Rear Projection...
It won't turn on and we don't have a remote control. What can we do ? Mitsubishi Medallion HD 1080
not knowing model number I will suggest a few things: if green power light comes on for a few seconds and goes out:
On front of set press and hold both the Menu and Input (device) buttons at same time for at least 5 seconds and release both.
Power light should blink a two digit error code like 2 blinks,,2 blinks,, a pause and repeat it several times.
This is a error code that indicates what area problem is in, let me know what error code you find and I will tell you what it means----if set has been unplugged you will have to try to turn it on and let it fail before you go for the error code.
SD TECH
Mar 31, 2011 | Mitsubishi Televison & Video
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
193 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
