Plastic rack that hold up the vegetable bins is broken. The rack is in just above the freezer. The freezer is at the bottom and has a little bit of ice build up. Can plastic rack be repaired by expoxy glue and what causes ice build up in defrost free freezer? Is there a manual I can refer to?
SOURCE: frost free fridge freezer has
yes,
you have a defrost problem, three things..
one, defrost heater could be bad,
two, bi-metal could be bad,
and three, the timer could be bad.
any of these three items getting bad would result to one symptom.
ice buid up at the bottom of freezer section.
tnx 4 using fixya,
drcool
SOURCE: Hidden Ice build-up inside plastic bottom cover of freezer
Generally, icing is the result of too much water vapor inside the unit, blockage of the circulation channels and too much packing in of the box. The water vapor is generally caused by: uncapped items in the fridge, opening the door too often, humid conditions, bad door seals. There is of course, there is a possibility that the defrost cycle on the unit is not working. About once a day, depending on the brand, you should notice that the fans and compressor don't run and you should hear a bit of creaking, sloshing or other strange noises as the ice melts. If this is not happening, your defrost timer or the coil it heats could be bad.
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
SOURCE: Refrigerator doesn't defrost
theres a defrost control on the unit that is probebly bad. its in the upper right of the refrigerator aand depending on the unit is either solid state or mechanical
