Question about Panasonic PT-AE700U Multimedia Projector
Hdmi stopped working
I recently went to watch my Dish HD and noticed I was no longer getting a picture from the HDMI input. S-Video works on the projector, but not HDMI. Tried a DVD player with same cable into projector, but no picture, even tried new cable, but neither the Dish or the DVD player showed a picture. I have to assume it is the projector.
Any ideas? Thanks!
Posted by sectorfive on
  • 1 more comment
  • Seorse Dec 13, 2007
    HDM(I does not work. No picture.
  • typiak Oct 01, 2008
    Hdmi is dead (no picture).
    I think i had to replace the mainboard but i don't know where to find it.
  • Winbot Dec 27, 2008
    Blue screen registers "HDMI" or any other input mode, but doesn't play signal from computer or DVD player.
5 Related Answers
Marrie
Marnus Jacobs
  • 563 Answers
SOURCE: Panasonic PT-AE900U
Very confusing posting !
RGB input for DVD Player ?
HDMI input missing ?
Posted on Apr 15, 2008
Motobias
Tobias Mueller
  • 6 Answers
SOURCE: Blueish tint on picture
no... lcp panels will look different when going bad ! this is the polarization filter, most of the time the one BEFORE the lcd panel (blue in this case). these should be cheap but are not easy to get...so you might pay quite a lot. you can also buy polarization filter sheets and cut them to size. keep in mind to check for the right orientation !
Posted on Jun 10, 2009
Anonymous
SOURCE: Panasonic PT-AE2000U All three HDMI Ports stoped
WOW. I just experienced the same thing. None of my HDMI ports are working, though component is fine. I've had my unit since November 2007 and had no problems until this. I think the HDMI board has gone bad and will require replacing.
Posted on Jun 21, 2010
Anonymous
SOURCE: Hdmi inputs does not show a picture. The inputs
I'm having the same problem. The projector stopped recognizing any input over either of the two HDMI inputs. The JVC RX-D411S receiver was working fine up until I used the VGA input with a computer and since that time, HDMI has not worked (despite working fine before). I tested two HDMI cables into each of the two ports but nothing! All other inputs work fine.
Posted on Jul 06, 2010
ABRsvcs
  • 4234 Answers
SOURCE: HDMI inputs do not show a picture. They worked
This is likely a problem with the receiver not the projector. If the setup screen from the receiver is displayed through the projector, then the projector is functional. If the actual signal is not displayed, then the receiver is not sending the signal. The setup screen is generated inside the receiver and is injected later in the video path than the input signal. Try a direct connect from the signal source (other side of the receiver) to the projector. Again, if that works, then the problem is the receiver.
Dan
Posted on Aug 21, 2010
2 sec Blip to picture
Are you saying that this happens only when you are using the RF input? Is it not happening when you use the video input from the satellite receiver? Try a DVD player on the input of the video where you now have the Satellite receiver connected. Let me know exactly what you mean as i need a little more information so I can assist you.
Jul 14, 2007 | JVC HD-52G886 52" Rear Projection HDTV
I have a Denon avr-3808ci. I have a Dish Network DVR and a Sony KDS-60A2020 tv. If I connect the HDMI cable on the DVR directly to the tv, I get picture and sound through the tv. If I connect the HDMI...
You are correct. I feel your pain. This will not work.
HDMI is a pure digital signal and the providers require the content coming over the Dish DVR to be COPY PROTECTED. So it will not work unless the HDMI cable goes directly from the DVR to the TV. This is to stop people from being able to make their own recordings of Dish shows, or making copies of your DVR recordings. If you really want to run things through your reciver, you're going to have to use the "component" or "composite" video feeds, not the HDMI. Sorry.
Sep 18, 2011 | Denon AVR 3808Ci Receiver
I have an longtime problem with my flm 3232 polaroid hdtv. I have dish network service with the dual receiver. The 3232 is the second tv connected via a coax cable. it work fine on the tv cable input...
Hello, you probably already have gotten this resolved, but I do have some answers to your post. Any cable that you have running from TV1 to the TV2 will nor give you a true HD picture. You could get a CAT5 cable with HDMI ends, but the longer the cable, the less true HD you have. The best resolution to this is to get an additional receiver, or to just stick with the SD picture. If you have any more questions, feel free to e-mail me at [email protected], or you can find us on Twitter!
Becki Barned
DISH Network Customer Service
Oct 14, 2010 | Polaroid FLM-3232 Television
HDTV no over the air signal.
No... Andraade11,
There is nothing exclusive of using a HDMI port...
you can have it all.
You are still able to switch right back to your old configuration...
I believe you merely need to step through your
"SOURCES"
Unless Dish us incredibly behind the curve
they used a HDMI to bring their signal to your set...
and add ($$$) a LOCAL "OPTION" into
their feed... but if you ALREADY had an antenna
hooked up... you should be able to switch right back to that source... or a VIDEO PLAYER obviously IF you have one)
and/or a SECURITY screen
(if you have a compatible camera or server)
Etc. etcetera...
Carnac the Magnificent
Apr 05, 2017 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
No longer getting video feed through Home Theatre receiver
HDMI ports 5 and 6 on the back of tv no longer are working. (We had a series of thunder storms so don't know if that is how they got damaged or if it was something else) but moved HDMI input cable to HDMI port 4 on tv and everything is working again. Service call placed for warranty service on tv to repair bad ports.
Sep 14, 2009 | Sharp Televison & Video
Sony Wega Trinitron HDTV Blue Screen with Sound
Had similar problems with HD cable on dvd. swapping with another cable solved the problem.
Aug 11, 2009 | Televison & Video
Hitachi 50V720 No sound with HDMI - no Component video inputs
Right now there seems to be many people with the same TV problems with sony and HDMI cables. Most of the solutions are resetting the TV and sony product. Try leaving your TV unplugged for a hour to let it reset itself.
Feb 17, 2009 | Hitachi 50V720 Television
Hd tv
My HDMI has stopped working. I have had a technician from Dish network out to my house 3 times and they have replaced the receiver and the HDMI cable and were unable to get the set to work all I get is a blue screen and a message which reads no signal. I also cannot use mt set using 3 rca cables connected to the component input when set to 1080 I keep intermittenly get a black screen then a blue screeen and sometimes a no signal message. I have to watch the tv set to 720 on component 2 and it is the most stable in that setting. Please send help
Jul 06, 2008 | Protron PLTV-37 37 in. LCD Television
HDMI connection???
Hi Greg,
Again, if you have a high definition dish box with HDMI output,and a dvd player with HDMI output,please connect them both directly to your TV HDMI inputs.
When watching TV(dishnetwork box).remember to switch the HDMI video inputs.
Same as your DVD player,you need to switch it under your TV video input.
solutiondoct
May 28, 2008 | Denon AVR-2807 Receiver
Panasonic PT-AE700U Multimedia Projector Logo
218 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
