Question about IBM ThinkPad T30 2366 Notebook
Ibm t30stopped working
Power adapter voltage is ok, no light or sounds
Posted by phcr7 on
Anonymous
    Novelist:
  • 85 Answers
Depending upon the model and battery, it is either a power problem, a connector problem, or a problem with the battery. Does the machine run with the battery, and does the battery seem to charge even if the machine is not working?
Posted on Nov 16, 2007
Battery not charging
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
May 21, 2013 | Dell Inspiron N4030 14" Dual Core 2.13GHz...
My HP Pavilion G6 laptop will not turn on. I have tried another charger a d battery and its still not turning on. It has no lights, no fans or sounds. It just stopped working. Any advice guys?
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Apr 12, 2013 | Computers & Internet
Toshiba satellite c660 motherboard not power
Sep 04, 2012 | Toshiba satellite c660
Compaq 610 laptop will not power up, any fix?
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Aug 05, 2012 | HEWLETT-PACKARD Compaq 610 Notebook
I donot have any light or power when I started my LAptop Power jack is ok
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 01, 2011 | Acer Aspire 5500 5570-2609 Laptop
Hi, my lenovo 3000 Y 410 notebook does not turn on. I removed the battery and connected the AC adapter but i don't get the power supply to the laptop. i can't hear even a beep sound when i tried to turn on...
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Dec 18, 2010 | Lenovo 3000 Y410 Notebook
My Acer Aspire One AOD260 not charging the battery, can you help me?
Nov 28, 2010 | Computers & Internet
My hp DV5 not charging and the adapter is ok.if I put adapter into itthe light at the charging will on but it will not charge.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Jun 25, 2010 | Computers & Internet
No power on but adaptor god
Feb 23, 2010 | Acer Aspire 3000 Notebook
Dead laptop
hi there if you are having some problems with laptop starting up then i would look at the power cord that charges your battery and make shure your battery is locked in the slot as well . what type of laptop you have there ? is the power cord adapter still working ? it may not be charging your battery sometimes this will happen before you take laptop to surgury make shure that the power adapter cord is still charging battery ok to do this plug in power adapter and using a multi meter check to see the voltage that is comming from adapter plug ok on the adapter it will tell you the input voltage and the output voltage that you should be reading on your dc multimeter ok try that first ill wait on a fixya soon bye for now
Jul 19, 2008 | Acer Computers & Internet
IBM ThinkPad T30 2366 Notebook Logo
Top IBM Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Thomas F. Schneider
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
