Question about Creative Labs Zen Touch MP3 Player
HELP!!!!!! When i turn my zen player on the screen has a whole bunch of white lines on it...everything still works its just the screen!
Posted by Alleygator on
Cary Farah
    President:
  • 4,402 Answers
Screen is bad.
Posted on Dec 17, 2007
Wen i installed my new logitech webcam 300. everything installed properly. but wen i use the camera a whole bunch of white lines run up and down the screen. verticle lines. ive tried changing settings, but...
Try to rotate the web camera lens adjustment knob. It controls the images quality of the camera. It is located in the front face of the cam. But if nothing happens right then take your camera back from the store you bought it.
Dec 23, 2009 | Logitech Webcam
Only white screen appears while starting.
My Creative Zen 16Gb got to the stage where every time I turned it on I would get a white screen. I tried many so called solutions, including those on the Creative website - nothing really workd for any length of time. Eventually, suspecting is was a connection issue with the dispaly, I held the Zen in both hands and twisted the case a few times - nothing broke and my Zen has been working faultlessy for the last three days. Hope this helps.
Nov 17, 2009 | Audio Players & Recorders
Blank Screen
in cases of water damage remove zen cover get a soft brush old toothbrush will do brush the circiuts well. now put cassing back on. If this fails then i think its time to buy a new one.
Sep 04, 2009 | Creative Labs ZEN V Plus MP3 Player
White screen
I get the white screen of death as well from time to time and I found this video and it actually worked for me.
http://www.youtube.com/watch?v=a8g0sh7pc54
Hope you have the same problem as me and this should help out just do what he does:
When the screen goes white, let the music play, put it on hold, wait until the screen turns black then take it off hold and the screen should be back on hope this helps.
Jul 13, 2009 | Creative Labs Zen Digital Media Player
White screen of death on my zen
I had the same problem with my Zen. I *downgraded* the firmware in mine to 1.03.04 and it seems to have fixed it. Per the Creative website, I first tried upgrading it to 1.20.02 and it only seemed to make it worse. I tried their recovery procedures to no avail.
You can download the downgrade here. It's and executable file, just have your Zen hooked up to your computer and execute it.
http://drivers.softpedia.com/progDownload/Creative-ZEN--GB-Firmware-Download-41209.html
Mark
Oct 17, 2008 | Creative Labs Zen Touch MP3 Player
Zen 4 gb media player
I've had the same problem and stuck a paper clip in the little whole at the bottem that says reset. It's working just fine now.
May 19, 2008 | Creative Labs Zen Digital Media Player
Sansa problems!!!
i recommend that you open it up and see if any connections are loose
May 07, 2008 | SanDisk Sansa E280 MP3 Player
Screen is white but music still plays
I have the same problem .. But i found a trick ...When you have a blank screen.
1 you must listen music else press play until you listen it
2. flip the switch on the side to lock position
3. press on buttom the next tune 1-2 seconds
4. you will have a black screen ( you listen the music again)
5. flip the switch on the side to normal position.
6 the screen appear ok now..
7. else repeat ( most time once is ok but sometimes 2 or 3 times)
connex_bern
Jan 31, 2008 | Creative Labs Zen Digital Media Player
Creative Labs Zen Touch MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
