2004 Pontiac Grand Prix Logo
vicky sullivan Posted on Apr 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wont start sometimes
I can start and drive my car and then go to start it again later and it wont start but I can try it again 5minutes or longer later and it starts fine but then it does it again. whats the problem
  • Anonymous Apr 16, 2014
    could be timming off does it take a couple cranks to start thats indication of it also could be an ignition or possibly starter spring check for a starter fuse first but replacement starter and time to change it only take bout 20 mins at most 3 wires and cant put them on wrong post
wolf
Level 2:
Habit-Forming:
  • Pontiac Expert 180 Answers
  • Posted on Apr 16, 2014
wolf
Pontiac Expert
Level 2:
Habit-Forming:
Answers
180
Questions
0
Helped
71317
Points
467
GM cars have bad problem with security system. If you key turn light and will start other time will stick and need shaking to turn over and won't start just replace the key. Security system need some times to refresh the memory.
1.turn key ON for 10min.
2.turn key OFF 10sec.
3.turn ON 10min.
4.turn OFF 10sec.
5.turn ON 10min.
turn OFF ON and start
total of 30 min. to refresh the memory
the next step is more expensive and need some skills.
on top of the ignition switch is a sensor go bad
replace ignition switch with the sensor and do the learning process from step 1 to 5
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Apr 28, 2009
SOURCE: car wont start...sometimes
Sounds like a bad starter solenoid, usually cheapest and easiest to replace the starter and solenoid as a unit. It is always best to check for power between the solenoid and the starter with a test light, if the solenoid clicks but the test light doesn't light up you have found the problem in the solenoid.
Anonymous
  • 73 Answers
  • Posted on Mar 23, 2009
SOURCE: my 1999 pontiac sunfire won't start sometimes
so you changed the air temp sensor because ginko wrote the same thing in solution 8 how about coolant temp sensor
Anonymous
  • 921 Answers
  • Posted on May 09, 2010
SOURCE: pontiac grand prix 2003 has trouble starting
you have a bad battery, if it more than three years old it is suspect, measure voltage it should read 12.5v minimum, if not trash it and install a new one. but also it could be as simple as very corrosion on the cables and post, if they look dirty, clean up with a wire brush real good and tighten it down firmly. Batteries are designed that if you lost you alternator and are just running on battery power and the car finnally gives up, if you wait another an hour, it has a reserve capacity that will allow you a couple more miles usually. i was stranded in the desert one time in the middle of nowhere 60 miles from home and used this technique, i had to do it three times before i got home but then that thrashes the battery and you'll have to replace it. Make sure that your belt is not loose and that its charging up the battery as you drive. You can also check this my monitoring your analog gauge to see if its on the plus side, if you don't have this gauge, then just use a voltmeter and check it while running, it should be around 13v, if its charging the battery.
can you rate this. thanks!
Testimonial: "Quick response and was helpful."
Anonymous
  • 80 Answers
  • Posted on Jul 20, 2010
SOURCE: Intermittent problem starting the car. Sometimes
check fuel pressure regulator..how many miles are on this car?
Jonah Oneal
  • 14092 Answers
  • Posted on Apr 10, 2011
SOURCE: drive 2007 grand prix. wont
SOUND LIKE ALTERNATOR NOT CHARGING BATTERY.CHECK BATTERY VOLTAGE SHOULD BE 12.6 VOLTS.MAY SURE BATTERY CABLES CLEAN AND TIGHT.WITH ENGINE RUNNING CHECK ALTERNATOR OUT PUT AT BATTERY.SHOULD BE 13.5 - 14.5 VOLTS WITH ENGINE RUNNING.IF ALTERNATOR FUSE GOOD AND ALTERNATOR BATTERY FEED WIRE AND VOLTAGE REGULATOR WIRES OKAY NOT DAMAGED.DRIVE BELT NOT SLIPPING OR BELT TENSIONER NOT DAMAGED.ALTERNATOR MORE LIKELY FAULTY.TURN OFF RADIO FIRST.BEFORE REMOVING NEGATIVE BATTERY CABLE TO KEEP FROM LOSING RADIO CODE.
Mazda 3 Transmission not working on cold starts
There may be moisture in the transmission fluid that is causing ice to block the valves. When the transmission is hot, change the fuid
My toyota harrier 1999 doesnt gear up, sometimes i have to restart it so ican drive normally like 5minutes,,when i fully push the gas pedal it makes a ramming sound and it stutters
you are not in USA, so post country.
the harrier here is Lexus RX.
so not posting that , nor posting what engine is in car makes
all answers wrong.
generic answers.
1: get a tune up, (the operators guide has a list. the 60,000 mile (100km) column are the critical parts. as is any cam belt.
1helpful
Have a golf gti 1996 sometimes wont start ,no spark then try again later and it starts and runs normal have changed crankshaft hall sensor .still the same.can run for days then wont start for a day,i...
check ignition S.w . check fuel pump. some time reading coil if getting hot it will not start make sure this happend when engine hot . but if when cold engine you have fuel pump or ignition S.W
Car starts sounding like it has fuel starvation spuddering
Sounds like the vent on your gas cap is blocked.
The next time it dies, try opening the gas cap and listen for a sound like air escaping. If you hear this, it should start right back up again.
If I'm right, you just need to replace the fuel cap ($5 at any gas station or auto parts store) and you'll be good as new.
3helpful
2answers
91 Accord Car will initially start then when driving it will die sometimes starts right away sometimes 10 or 20 minutes later but has gotten more frequent about dying and taking longer to start
I have a 1991 honda accord dx that had the same problem. while driving it would just completely shut down. after about 5 minutes it start and run for a while then shut down again getting more frequently. There was a recall on the ignition control module (ignitor) which is in the distributor. call your local honda dealer with your vin # and will tell you if yours was replaced. If not I bought one from parts store for $60 or you could take a chance and buy one from a junk yard. I bought the whole distributor for $20 as a back up.
2answers
Ford laser 1990 model wont start
ITS PROBLAY THE IGNITION COIL, OR IGNITION MODULE, I BET ITS THE COIL, BECAUSE USUALLY WHEN YOUR MODULE GOES OUT IT JUST DIES AND WONT START BACK, SOMETIMES THE COIL WILL GOES BAD, IT WILL RUN SOMETIMES AND NOT THE NEXT TIME.. GOOD LUCK KEITH..
Top Pontiac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
