Unlock a philips receiver
Hi i was given a philips dtr 1500 freeview box but when the time hits 22.00pm all the channels become locked and ask for a pin code the people i got it off dont ever recall putting a code in so now im in a pickle so if there is anyone out there who could possibly help me i would appreciate it thanks x
Posted by bexyboo on
5 Related Answers
Anonymous
  • 2985 Answers
SOURCE: freeview receiver
This aeems to be a dud device return to seller or Philips
Posted on Jan 16, 2008
Vista Electronics
  • 1694 Answers
SOURCE: remote handset codes
www.remotecodelist.com ..........................................T.
Posted on Mar 22, 2008
Anonymous
SOURCE: Philips freeview box DTR 220
Same problem with Channel 71 CBeebies. Tried rescanning which worked initially for a few weeks but it's back and rescanning does not fix the problem now.
Posted on May 16, 2008
Ekse
  • 13434 Answers
SOURCE: freeview probs
can you try a external antenna on it?
Posted on Jun 19, 2008
davie2004
SOURCE: retuning Philips DTR 1500 digibox
Had same problem. Remedy is to put digibox back to factory reset. Dis-connect from mains. Keep pressing + button on front panel as you re-connect to mains. Red LED will be on, when orange LED blinks release + button. briefly press + button. You have solid red LED and blinking red LED. Enter code 9 9 0 0, by remote blinking LED will show green. Wait a few minutes and the instalation page will appear on screen. Go to update and start as you did before and C5 should be installed. Hope that helps.
Dave
Posted on Sep 30, 2009
Testimonial: "Dave's advice was very helpful - see my comments on the relevant page - I'm extremely grateful both for his help, and for this website. Ron Sherwin"
Problems withthe digital switchover and retuning my freeview box!
There are a few problems turning up as a result of the update. Do a factory settings on the box if it has the option to do so. Be aware of the actual transmitter you are on and the channels/frequencies it uses so when tuning you know whether its finding channels at the bottom, middle or top of the band. Sometimes you may need to unplug the aerial upto or after a particular channel to stop the box tuning unwanted transmitters. If you are picking more than 1 transmitter up you will often get extra channels in wrong locations
Nov 06, 2009 | Philips Televison & Video
Freeview probs
Jun 19, 2008 | Televison & Video
IVE GOT A DTR DIGITAL TERRRSTRAL RECIEVER BUT NOW LOST ALMOST ALL THE CHANNELS I WAS GETTING BEFORE.I HAVE ONLY GOT 5 OF THE NEW CHANNELS INSTALLED
Thanks for the info. You didn't state the manufacturer but I think you must mean the Philips DTR1500/05.
The official advice when a retune has not turned out as expected is to try again at least twice, but from experience I'd add the advice that you should do so at different times of the day.
There are some boxes which are known to have problems with the retune; yours is not on the official list but the channel numbering details which you've given do confirm that it's primarily a problem with your receiver and not with your aerial system or reception quality.
There is no user fix for this. All you can do is to contact Philips directly, but your box is a 2003 model and no longer supported by the manufacturer. OnDigital/ITV Digital/Freeview technical standards have evolved a great deal since then as one operator replaced another and many earlier chipsets have been found to be incompatible.
Contact Philips by all means, but I think that you may be better off investing the £20 or so needed to buy a newer receiver. If it helps, yours uses a lot more power than the newest models so you will make some energy savings and your box was only designed with around a five year maximum expected lifespan anyway.
Sorry I can't give you a more positive or encouraging answer. See the web address below which will show examples of other models with similar or worse issues to your own.
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
Oct 08, 2009 | Televison & Video
Philips freeview digi box dtr1500
thanks my daughter solved the problem to unlock parental lock or parental pin number she tried four zero digets 0000 no success then she put in four numbers one 1111 and it unlocked the parental lock .hope it can maybe help someone - margaret
Oct 01, 2009 | Philips Universal PH301S Remote Control
Same problem
At lunch time today all freeview boxes have to re-tuned so you will get channel 5 and ready for HDTV.
Some old boxes according to sources are packing up altogether so you have to keep this in mind.
You can re-tune your freeview box using your OSD (on-screen display) and locate re-tune.
If you are unsure how to re-tune the box which many people are having problems with please visit this website for a guide for your model box >>>>
http://www.tvretune.co.uk/
http://www.tvretune.co.uk/productmanuals/
Regards.
Sep 30, 2009 | Philips Televison & Video
Retuning Philips DTR 1500 digibox
Dave
Just installed new tvonics250 freeview + box
I have one of these boxes and one of the things which has caught me out a couple of times is that the remote can control three devices. To turn the Z250 on and off you may need to press the DTR button at the top of the remote first. When you press the on/off button on the remote the DTR button should light up red to let you know the signal is being sent to the Z250.
You are probably aware of this but just in case you weren't
Mar 02, 2009 | TVonics Televison & Video
My Thompson Freeview box keeps stuttering/time lapse freezing.
Hi Ive just bought a thomson dtr box and the picture keeps freezing .new arial new cable etc.well ive just tried a £20 freeview box and its fine good clear picture and dosnt freeze.I had a good signal when using the thompson box and its the box load of rubbish taking it back to shop.
Apr 14, 2008 | Televison & Video
Feb 14, 2008 | Televison & Video
Freeview receiver
Jan 16, 2008 | Televison & Video
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
