Question about Pioneer DJM-600 Silver Professional DJ Mixer with Auto Beat Cou Home Equalizer
Power shortage with new djm-600 US model used in UK
Hi
i have just purchased from a US seller a brand new DJM-600 mixer. Upon plugging in the power cord to an adapter (universal) the power light flashed and failed to switch on. The power cord appeared to be a polarised alternating current line plug (one side larger than the other) so not sure if this has caused the device to short circuit somehow?
Can you advise on how to rectify this or if it seems to be a more serious problem?
Thanks
Posted by ash_78 on
  • 3 more comments
  • ash_78 Nov 04, 2007
    Thanks Akira. Had eventually discovered the voltage difference was the problem. If anyone else purchases a US appliance and intends to use it anywhere else in the world that uses 230V power outlets, they need a step down transformer to convert the power from their power socket 230V back down to 110V. The mixer is currently in for repairs - it will either be the fuse or the power supply that has been blown. Hopefully the former.
  • kilcot Dec 18, 2007
    i bought a djm 600 from an american seller on ebay when it arrived here i got a transformer and pluged it in and nothing happened it still does not turn on i have tried a few different transformers and still does not work
  • Anonymous Jul 07, 2008
    hey iv got the same prblem with my djm 600. it wont turn on, yet theres power goin thru n past the fuse. Any idea which would have been the next component that would have been fried thus breaking the circuit? Were you able to find the problem?
  • guiltyparty Jul 31, 2008
    How much did this cost you to repair in the end, and where did you go (London?)?
    Have done the same thing to my Japanese DJM600, absolutely gutted, got the cables mixed up and killed it.
Anonymous
Hey iv got the same prblem with my djm 600. it wont turn on, yet theres power goin thru n past the fuse. Any idea which would have been the next component that would have been fried thus breaking the circuit? Were you able to find the problem?
Posted on Jul 07, 2008
Anonymous
Don't have a solution but my 600 was plugged in and the power was intermittent when looked at more closely the + & - were loose in the plug and i think it has shorted i used a multimeter to check the path from plug to initial internal fuse but it was fine, any idea which would have been the next component that would have been fried thus breaking the circuit?
Posted on Feb 01, 2008
Anonymous
    Problem Solver:
  • 4 Answers
If it is a grounded power cord make sure the voltage is correct some are 115v and others are 220 also some have switch to select voltage plus there is two fuses on that particular model check both and replace with same volt and amperage if it does'nt work reply back to me!
Posted on Nov 03, 2007
I have a djm 400 and it has started producing a buzzing sound through the speakers. I can take the same speaker cables from the djm 400 and hook them up to my backup mixer and the buzzing goes away. What...
Since it works with your other mixer, the DJM400 is probably fine. You have a ground loop.
Make sure ALL, and I do mean ALL... (re-read that if there is any confusion) interconnected equipment WILL BE powered from the same receptacle or source. If speakers or amps are powered from one place and the DJM is from the other end of the room you likely have a ground loop and you can ex[ect buzzing. Run extension cords alongside the audio leads if necessaryy to carry power from where the amps or speakers are plugged in back to the DJM400 and ANY pther connected equipment.
Jan 07, 2011 | Pioneer DJm 400 Professional DJ Mixer
DJM 500 Mixer not turning on
Seems that the power supply is down.
If your not a technician, visit one or bring it to your local dealer.
regards,
Gerard
Mar 14, 2010 | Pioneer DJM-600 Silver Professional DJ...
DJM 500 & 2 1200mkIIs -- Very Low Sound With Multiple Speaker Sys
are you sure you have your tt's plugged into the phono line with the master booth knob turned up? Check the mixer too cuz the techs should be square.
Jan 15, 2009 | Pioneer DJm500 Professional DJ Mixer...
PIONEER DJM 600 . NO POWER.
I have the same problem, One day I open the djm-600 for replace the jack whole (easy), then of this when i close the mixer my pioneer died, but when I push the power button I can listen a little sound like ¿voltage running? Please Help !!!
Thanks
pd: sorry for my bad english
Nov 17, 2008 | Pioneer DJM-600 Silver Professional DJ...
Djm 600
start with connections and try to clean fader with lubricant contact cleaner from radio shack or any electronics store.
Sep 10, 2008 | Pioneer DJM-600 Silver Professional DJ...
PIONEER DJM 600 MIXER KEEPS PEEKING RED SHOWING HI SIGNAL AT LOW VOLUMES
check your input (cables and device)for bad or short circuit cable-bad plug--connection between inner conductor and shield. of the cable(test with new one)------you can disconnect inputs one by one until you find the bad one.and change it.
Aug 27, 2008 | Pioneer DJM-600 Silver Professional DJ...
555 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
ThaMp3Doctor
ThaMp3Doctor
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
