SOURCE: monitor no display
hi, check out the connector pins if any is damaged or bent, if not try it on a different system just to confirm that its not the display card problem, let me know??
SOURCE: how to disassemble monitor Dell 1800fp ?
remove the base - either button release, or 4 screws. If there are any other screws in the monitor case, remove them. Depending on how old this model is, Dell monitors usually need to be pried apart, the front coming off and separating from the back. If this is the model with the vents on the top and bottom, this is a good place to start (separate the front from the back by prying it gently all the way around) If it's a newer model, similar to a 1905FP, the front bezel needs to be pried away from the back. The front bezel piece is only about 1/4" think, and you may be able to start opening it with a very thin but wide flat screwdriver.
SOURCE: Dell E173FPb monitor has gone
http://www.electronicrepairguide.com/dell-e173fpb-lcd-monitor-repair.html
SOURCE: does a Dell monitor (E173FPB) need a connection
The E173FP does not have built in speakers. You need external speakers.
SOURCE: MY DELL E173FPb FLAT MONITOR WILL NOT COMPLETELY POWER UP IN GOES
Most common failure in this model is shorted transistors in the inverter circuits caused by poor solder connections, see pictures here for guide: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
