Question about Whirlpool LGV4634JQ Gas Dryer
Kenmore home dryer not heating but will turn on and spin
This page says check thermol fuse, what does it look like and located? also if no ohm meter avail. can i jump to check? thanks for any advise
Posted by drmcgow on
Jeff Rockwell
  • 5,911 Answers
If your dryer turns on, but does not heat, the Thermal Fuse is GOOD. A blown Thermal Fuse will stop a dryer completely.
If the dryer turns on, drum spins, but you have no heat, any of the following components could be bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
Getting to those components to determine if they are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the the seam in the front about 2 inches in from each side.
The heating circuit should be troubleshot with the dryer UNPLUGGED. Resistance readings are as follows:
Heating Element (located inside heater box) - take reading across the two RED leads on the heating element. It should read 9 - 13 ohms.
Thermal Cut-Out (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended to replace BOTH components at the same time. They are often sold as a set.
I hope this information is helpful to you. Post back with comments if you have any further questions.
Posted on Nov 02, 2007
Anonymous
OK We have a Kenmore model 72501 which lost heat but still ran fine in the cool modes. I switched the igniter out which didn’t work; then changed out the coils then final the fuse at the rear which is a cut out for the heat. I was told that lint build up is the problem of this going out. I figure it was the large blanket with about a poodle size lint ball that did it for us. Anyway although I had reviewed and check all the other things first and that the igniter was old and ready to go out these things needed to be replaced so I did so. If you have any other questions please feel free to email out any comments; all the ones I have read help a lot so I feel I should be putting in my own experience for others to learn by. Thanks for a wonderful site.
Vince -Long Valley
Posted on May 29, 2008
How do i test the dryer thermol fuse
Please rate me
You can check the thermostat/thermistor one at a time by removing the two wires and checking the continuity with an ohm meter .
(The thermistor/thermostat should have/show continuity)
Thermal fuse...If it overheats, the dryer will not operate.
It's located on the blower housing. It cannot be reset.
A vent clogged with lint can cause it to overheat.
You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
Dec 27, 2010 | Dryers
Dryer not heating - I replaced the heating element and it still isn't drying.
  • Rank: Guru
  • Rating: 92%, 36 Votes
Yes there is a thermal fuse and a hi limit switch. The hi limit switch is attached to the heating element casing. You said the heating element checks out If you checked it with an ohm meter and it checked out good. If you checked it visually double check it. The hi limit can be checked with an ohm meter it should show continuity. If you dont have a ohm meter you can jump the wires by connecting them using a paper clip or copper wire. Make sure to tape them with electric tape. The thermal fuse is connected with the Heating element and hi limit by one wire and is located at the bottom back of the dryer and slightly to the right as you face the back of the dryer. It is a small two wire fuse and once it trips you have to replace it you can check it and test it just like the hi limit switch. Be careful and always unplug the dryer before starting any repairs. I hope this help. If you need me to clarify anything just let me know. good luck
Aug 25, 2010 | Whirlpool Dryers
A Kennmore electric dryer, model 697267. Heating element checks out ok. Soninlaw said breakers are ok. Dryer drum turns but no heat? I'm 640 miles away, is there a thermal fuse in the circuit.
Aug 25, 2010 | Dryers
How do i replace the heating coil at least thats what i think the problem is the dryer spins and blows air but the air is cold.
first access the element case and with an available multi-meter check the hi-limit,cycling switches and the element for continuity the switches will show like a switch either 0 ohms- on or no ohms-off/the element should show a few to 50 ohms/ if these are not bad,then check the thermal fuse located on the vent tube outlet it will check like a fuse(0 ohms-good/infinity-bad)
Mar 19, 2010 | Estate EED4300TQ Electric Dryer
Radio problem
First thing is check you accessory fuse located on the driver side of the dash. Or you may actually have to check the OWNERs Manual to see what fuse does what. The back of the fuse door usually has fuse schematics. If neither of these are available use an Ohm meter to check continuity on the fuses. Change with SAME fuse rating if there is no continuity between the poles.
Mar 10, 2009 | 2001 Dodge Neon
Kenmore Dryer won't heat
ok you moving in right direction but you jumped a step,,you already checked the thermal cut offf and the operating thermostat,,those where the two on the side of the heater housing,,you should have checked the thermal fuse and the thermistor,,they are on top of the blower wheel housing tuck a lttle to the left,,since you seem that you know what your doing just jump them out starting with the thermal fuse,,,keep me posted on the job
Jan 04, 2009 | Kenmore 63942 Dryer
How do I locate and test the fuse?
fuse is usually smaller that safety thermostat and located on outer rim of element housing jumping it temp would show if bad or not but do not leave it that way ohm meter would be better
Jul 23, 2008 | Kenmore Elite HE4 Electric Dryer
Convergence power supply fuse
the fusable link... can be check with continutiy.. or a ohm meter......u need a meter that can do this when you put a meter across it it will read o ohms if good and infinate if bad some meter beep when it has near zero ohms meaning good... if you have any question. i can be reached at willie AT fordtv.com.... from your desciption it does sound like the fuse... However when you replace the fuse you have to make other repairs or it will fail again...falty solder connections is what cause this
May 03, 2008 | RCA HD52W59 HDTV Projection Television
NAD C350
Take a ohm meter and measure resistance from emiter to collector should have a few kilo ohm on output transistor.
If no ohm meter available , remove output transistors from circuit.
note position of transistor . you have a NPN and a PNP for each channel.
Replace fuse and power up. If fuse blows check bridge in the power supply.
80% of the time output transistor burn and blow the fuse.
before replacing output transistors check driver transistors they probably burnt also
Apr 29, 2008 | NAD C350 2-Channel Amplifier
Whirlpool LGV4634JQ Gas Dryer Logo
789 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Ned Halaweh
Ned Halaweh
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
