Question about Technics SL-PG480A CD Player
Help SL-PG580A I have an SL-PG580a and it shows F26 can you explain to me how to clear this so it works
Posted by hapie on
  • trynstpme Nov 12, 2007
    i also have this problem,except i have a slmc400,and the disc changer wilkl no longer play discs
  • hapie Jan 05, 2008
    I found that it was due to a communication error between components...after fixing the intial problem...a broken solder joint on the speaker jacks...I then dosconnected the pc board from all connections after about 5 mins I connected it all up again and it then began to communicate with all the parts and problem was solved....Maybe this will be of help to some one
1 Related Answer
Seamus377
  • 99 Answers
SOURCE: technics sl-pg580A
this player uses a philips mechanism, spindle motor failure is very common on these mechanisms, yours may be on its way out. take the lid off and insert a cd and if you can hear the laser trying to read the cd without it spinning, it's definately the spindle motor.
Posted on Dec 20, 2009
Codes f26 and then f27 for maytag model MFH 0710
F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start. unsure of f27
Dec 23, 2016 | Maytag Washing Machines
What means the code error F26?
F26 Boiling protection. The program is interrupted and the drain pump is operated. The display shows Technical fault F26. Call the Service Department. The buzzer is activated for 2 minutes.
Cause:
Temperature at NTC temperature sensor has exceeded 194?F (90C).
Remedy:
Check the heater relay and replace it if necessary.
Cause:
NTC temperature sensor providing inaccurate information.
Remedy:
Replace the NTC temperature sensor.
Cause:
Heater relay closed.
Remedy:
Replace the heater relay.
Aug 25, 2014 | Dishwashers
My maytag commercial washer display a code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
Error code F26
If opening and closing the door does not remove the error display, press Pause/Cancel twice
Oct 22, 2011 | Whirlpool WFW9200S Front Load Washer
Fault code f26
Jul 30, 2011 | Maytag Washing Machines
Washer says f26 and won`t spin the clothes out. is there anything i can do?
If opening and closing the door does not remove the error display, press Pause/Cancel twice.
The above procedure is the specified way by whirlpool technicians to clear the error code.
Feb 02, 2011 | Washing Machines
What does F26 mean
Hi, Well The error F26 does indicate a fault in the door switch circuit. There is a door unlock error that would display if the door is not locking or unlocking but the F26 means the control is not seeing the door switch open and close.This is most likely a problem with the door switch or a loose connection at the switch.
One thing to try first before scheduling service or replacing the part is to check the connections on the door switch.
You can unplug the washer first and remove the lower access panel and reach up to the door lock and try to feel for the connections and make sure they're tight.
Thanks! mannu_rakesh
Sep 11, 2009 | Washing Machines
Technics sl-pg580A
Oct 07, 2008 | Technics SL-PG480A CD Player
Splg580a
Im pretty sure this is to do withthe laser, try using a cleaning cd, put your head next to the player and listen to if the actual disc is moving inside.
this might evan be a problem with the cd motor.
Regards
Nov 01, 2007 | Technics SL-PG480A CD Player
Technics SL-PG480A CD Player Logo
319 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
