Question about Nokia N70 Cellular Phone
Nokia N70 fell in the toilet
My Nokia N70 fell in the toilet. I tried drying it with the hand-dryer, but it still doesn't turn on. Any suggestions?
Posted by meholdingon on
Anonymous
    Sniper:
  • 68 Answers
To help drying out the phone, I suggest taking the phone apart. (i.e. battery, sim card, back cover, etc) putting it all into a container of rice, Use a container that you can put a lid on. Let the phone set in the rice for a couple of days. The uncooked rice will draw the moisture out of the equipment. This will dry it out, but whether or not it shorted the unit out is your next step.
Please rate this solution
Posted on Jul 31, 2008
Anonymous
My phone fell into water, but was removed immediately. I dried it and after a series of failures where it refused to come on, it finally did. But now, the screen is just white. I can find my way around the controls but I can't SEE anything. How can I solve this without having to buy a new screen. It's an N70
Posted on Sep 12, 2008
Arturo D'Souza
  • 133 Answers
Usually after a phone gets water logged the battery goes down below 1 volt. If this happens the phone will not charge nor will it come on. If you are sure that it has dried up completely try putting in a charged battery and see. Before that if you have a multi meter with you check for any short across the battery terminals if it does show a shorting then its no way u can do it urself boss
Posted on Nov 04, 2007
Anonymous
No software
No driver
Posted on Dec 10, 2007
Two days back my cell nokia E7 fell into water and was there in it for 5 minutes.Intially it started after a while when we kept in sun n made it dry but later on it got switched off and till now its not...
First: Do this before:
Remove the battery and sim
Then DRY it with warm air (hair dryer) for 5 to 10 minuetes or more
but keep the dryer far of the phone in case it becomes too hot and be damaged.
keep do this till it turns on
IF it doesnt work, Find A MOBILE REPAIR STORE.
May 19, 2011 | Nokia E7 (16 GB) Smartphone
My n70 fell in water...and now error message appears - "Phone Start Up failed. Contact the retailer"
looks like its time for a new one. You can try and dry your handset out but be carfull you dont over heat it, remove the battery and cover.
Feb 13, 2011 | Nokia N70 Cellular Phone
My phone fell in the toilet idk what to do!!
I am not sure if this will help but here goes anyway. I assume you immediately removed the phone from the toilet when it fell in. Here is what I did in a similar circumstance. My wife once dropped her car keys and remote in the toilet while she was at work. Once she got home, I opened the unit up and using a hair dryer carefully dried off the printed circuit board. I then replaced the battery. The remote is still working today. Good luck! Whether this works out for you or not you should tell your Mom about it. Accidents do happen - my guess is she will understand.
Jun 27, 2009 | HTC G1
My Nokia N70 fell into waterand not working even after a week
try taking the battery off and try do dry the phone by using a hair drier leave feeck back
Jan 31, 2009 | Nokia N70 Cellular Phone
I have N 70 and it got wet,do you know a possible solution ?
take the battery out first do not switch on the phone dismandle the phone if u have blower the blow with it in a reduced temperatue make sure all the water are been dryed now reassemble it
Jan 08, 2009 | Nokia N70 Cellular Phone
N70 Fell in water, Only White Screen is Shown
Don't put the battery / power on. Take the phone to the mechanic / nokia service center on urgent basis. They will remove the remnents of the water and salt over the circuit.
If the problem is still not solved, either the power supply or the motherbaord will require a replacement.
Dec 16, 2008 | Nokia N70 Cellular Phone
My Nokia N70 fell in water i removed it's battery and dried it quickly but now when i opened it. It is just showing white screen. Nothing else is visible no sound no vibration no display. i cannot turn it...
take a hair dryer and dry the phone till u feel it completly dried off may be then it will work as same problem was with my 6300 phone and its still working
My express music 5610 fell in water !!
http://www.fixya.com/support/r3771170-phone_water_damage
Dec 10, 2008 | Nokia N91 Cellular Phone
Nokia N70 doesn't display anything?
You have to open it up to dry it up with a hair dryer , there is still water inside the phone. Do not turn it on until you have dry up all the water other wise you will damage the phone. Good luck
Apr 29, 2008 | Nokia N70 Cellular Phone
Its better not to use it because even if it be repaired this will not be reliable.
best solution ?
please dont forget to vote if you consider my suggestion helpfull.
Dec 28, 2007 | Nokia 7260 Cellular Phone
Nokia N70 Cellular Phone Logo
321 people viewed this question
Top Nokia Cell Phones Experts
Ekse
Zaid Anarwala
Zaid Anarwala
SANTHOSH
