Question about JVC XV-N55 DVD Player
How can i make my jvc xv n55 region free
Have tried the switch on holding various buttons and this does not work
please help me someone
Posted by ncc1701 on
5 Related Answers
Anonymous
SOURCE: JVC dvd player model XV-N650 unlocking codes
From another site...
Region code hack posted by mairel, December 18 2007:
A greeting to all, good after point to look for and to break the head, I could convert to multizona my DVD, I count them that I stay fillet. here they go them the procedures, I hope it serves them. 100% guaranteed.
1. Turn on
2. Open the tray
3. Press 0000 in RC
4. Change to any region you want 0 for region free
5. Press Pause
6. Turn off
7. Turn on again and enjoy
Posted on May 15, 2009
Michael Borelli
  • 979 Answers
SOURCE: changing the region code
This unit is hard-wired to be the region for which it was sold;sorry...accordianman
Posted on May 09, 2008
Anonymous
SOURCE: Region free code
yeah me too. damn that dvd player!
Posted on Jul 09, 2008
SOURCE: Unlock code for jvc XV-N652
Below is the only known process to unlock that model of DVD player. Does not work on 100% of dvd players.
1. Turn on dvd player
2. Open the tray
3. Press 0000 in the Remote Controller
4. Change to any region you want (0 for region free)
5. Press Pause to confirm your change
6. Turn off
Hope this works for yours, please post back if it does. Thank you for trying Fixya!
Posted on Mar 24, 2009
Anonymous
SOURCE: JVC XV-N316S Unlock Code how i can make region free?
Hi!
I would like to ask it,that jvc xv n 316 dvd to a player this firmware is refreshing.
Posted on Jul 20, 2009
My power switch is stuck. How can I fix or alternately turn on my I-phone?
If your phone is always out of a case, dirt could have lodged itself on the side of the button. Try using your nails t o clean it and it should work. However, If the button itself is the problem then try pushing and holding it down at various pressures (after cleaning ofcourse) if it doesnt work you can either fix it yourself watching various videos or take it to a specialist.
Sep 10, 2014 | Apple iPhone4 4G iPhone 4
Maytag Stove Error Message 5 A6
ok Alvin. help has arived .. turn off the power for a few min ( at the breaker box) turn back on see if clock will set . if not you may have a damaged membrain . now 5 A6 MAY BE A FAULT CODE.. in the control panel is a tec sheet with the codes . hope this will help .. mm
Dec 04, 2009 | Maytag Performa PAV2200
My garmin 255 nuvi will not power up. there is no reset button on this one and I have tried holding the power switch on for various amounts of time
let it charge via the usb for a few hours, then try holding the lower right corner of the screen, while holding that hold the power switch till it turns on then release when you see the message, "do you really want to delete all your data" <<< that erases your favorites and any other saved info, but that is how you reset your 255
bill
Oct 19, 2009 | Garmin nuvi 255W GPS Receiver
Someone else (I'm guessing) put my mp3 player on radio & then locked it any button I press to try to get back to the songs I downloaded shows a lock - help!
There's a little switch labeled HOLD on the side opposite the side with the MENU button. Switch it to unlock the buttons.
Aug 15, 2009 | SanDisk Sansa m240 MP3 Player
Start problem
Hi,If you hear the hum while you are pushing the start button and when you let off the button the hum stops, you have a notor going bad.
If you can get someone to help you, open the door, hold the door switch in, while someone else holds the start button, you try and turn the drum with your other hand. Sometimes the motor will start but, this only confirms the motor is bad and needs replaced. I hope this helps.
Thanks
Vic
May 15, 2009 | Dryers
Help please
Click the following link, select software and driver download and follow the instructions:
> HP PSC 1410 All-in-One Printer
Nov 15, 2008 | HP PSC 1410 All-In-One InkJet Printer
Sharp R-1450 microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
On these, it's usually a broken tab on the upper switch holder.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
That sounds like what's happening when you hold the Start pad - maybe you're moving the frame and chassis enough to help it work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Aug 19, 2008 | Microwave Ovens
5240 brother
I just solved my similar problem- switch off printer, open front door, hold down go (blue) button. Now switch on, holding the go button for about 10 seconds then closing the door.This left the lights all off, green light only when pressing go. Switch off then on, it worked! hopefully this helps someone else. Ross
Apr 18, 2008 | Brother HL-5240 Laser Printer
Wont turn on
Make sure the button on the left side that says on-hold-off is in the off position, then try turning it on by pressing and holding down the play/pause circle button on the front of the mp3 player.
Dec 19, 2007 | GPX MW3837 MP3 Player
Motorola L6 Blocked
You can remote onlock it using various sites on the internet but most incurr a fee for processing . unlocking you phone usually requiresa cable and specific software that are expensive so your best bet is to find someone local or go to the internet
Dec 05, 2007 | Motorola Mobility L6 Cellular Phone
JVC XV-N55 DVD Player Logo
311 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
