Question about HP Officejet 5510 All-In-One Thermal Printer
Paper jam No paper in the machine I opened flap to ink cartridges but they do not move into middle something blocking them?
Posted by judith1 on
  • Anonymous May 19, 2008
    I have the same problem with my 5510. Reset and shut off numerous times. No help.
  • cherry_girl2 Oct 19, 2008
    same thing. says "clear jam and then press ok." but rolls out paper at the same time it says jammed.
Anonymous
I have an hp office jet 5510 and its not print and it keep on saying cartiage is jam , the timeing is all mess up the leg that bring the paper out keep on coming up whilethe cartiage is going across is there a way of reset the print to get back the timeing
Posted on Mar 19, 2008
Ink Cartridge removal
stop sending any command to your printer, just open the cover of it and it will move to the middle in order to remove your cartridge, if nothing happens just pull it back with hand, it will move freely..
Apr 15, 2014 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
Ink holder will not stop in middle to change ink
Hi, normally when changing ink cartridge, once you open the cover the printer head move from home to the center of the printer and halted,if in case this not happen something wrong with the sensor, if the printer move from home to center just pull off the power cord to stop the printer at the middle or nearly at the middle just to remove the cartridge and replace it. Upon replacing the ink cartridge, just power on the printer and it will return home to its position.
Jun 17, 2011 | Office Equipment & Supplies
Error Code 6A00, printer not working MP830
Move you ink heads out of the way and look inside, you will see the waste ink sponges and a little white plastic flap that may be jammed in position, wiggle it a little to free it and then continue to move it to make sure its free. This should solve it for you.
Jun 23, 2010 | Canon PIXMA MP830 All-In-One InkJet...
How do i remove the old ink cartridge from an sx200 please this is the first time i have had to replace it, i have lost my instructions thankyou
instal your printer first. when it is instaled go to printer settings, then click on maintenance, then click on the option that says ink cartridge replacement. Follow the instructions and this will bring the cartridge to the change position!!
failing this you can unplug your printer quickly after you turn it on when the cartridges move, then you can manualy move into position.
Or you can download link here
http://www.retrevo.com/r/23134dj980/17/Replacing+Ink+Cartridges#q=Epson+SX200
Sep 09, 2009 | Epson Stylus Multifunction Inkjet Printer/...
1200 error
Turn off power to the printer and unplug it from the back of the printer.
Insert the power cord back into the printer. You will hear some clicks and motors moving. Pull out the cord again when this happens.
Open the cartridge bay by pulling the face forward and lifting the bay door up. The cartridge carousel most likely will not come to the center.
trying physically pulling the carousel to the middle. (NOT BY THE RIBBON CABLE) If you can not pull it to the middle push it far right as possible. Listen for a click.
After pushing to the right and hearing a click you should then be able to pull the carousel towards the middle easily. Remove the ink cartridges and power up the printer again.
You will receive an error along the lines of black cartridge missing. Open the bay, insert the cartridges, close the bay.
YAY problem fixed.
Hope this might helpful to you.
Please rate me if i am helpful.
Thank you.
Yboyandrei
Aug 22, 2009 | Lexmark X4270 All-In-One InkJet Printer
Paper jam when no paper has been anywhere near it, 1/2 INSTALLED
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 27, 2009 | HP Photosmart C5280 Printer
Do not know how to replace ink jet cartridge
open panel above printer paper cartridge should move to the middle pull towards you and replace old with new one the same way old one came out
Sep 21, 2008 | Office Equipment & Supplies
HP Officejet 7210 All-in-One Leaking Ink
the ink collector(well) hav accumulated much ink overtime its due to be serviced.remove the cartridges move the carriage to the middle remove the ink collector pad and clean , clean the collector with methylspirit check for the sensor beside and clean if blocked
Apr 26, 2008 | HP Officejet 7210 All-In-One InkJet...
Help
Reach into the papar slot directly above the display screen, (where you would place the paper to be faxed, pull outward, this will hinge downward
There is a small finger hole just below the fax/paper (face down) symbol. Pull outward, this will hinge upward.
The cartridges will move to the center of travel. If you get this far the instruction are on the underside of this flap. The cartridges snap out by pulling toward the front.
COLOR = #20
BLACK = #70
Jan 02, 2008 | Lexmark X125 All-In-One InkJet Printer
HP Officejet 5510 All-In-One Thermal Printer Logo
406 people viewed this question
Ekse
Thomas F. Schneider
