Question about Lands Phones
A couple of things re our MLX key sys...
1) We have a Lucent MLX Key System and need a manual to see if we can reprogram our conf room phone so it doesn't ring busy everytime. Been like that for ages. (Driving us all crazy running from the conf room to the front ofc to grab the calls!) FYI, we can make calls outbound, no prob.
2) Whether we can re-program, or we have to get someone in the Oakbrook, IL area to do it for us, we still need to have the phone moved from it's wallmount positon in an adjacent room, to a wall position in the conf room, about 15-20 ft away, so we can put the phone on the conf table; maybe even get a not-to-expensive conference mic for the table.
Any help on at least #1 would really be appreciated. Thanks!
Alan - 630-968-3300, 139.
Posted by Handiman on
Anonymous
    Sergeant:
  • 274 Answers
I couldn't find a manual for you to download but I did find a company which appears to have everything you asked for. They even have the manual ($160).  So check it out and then let me know if it solves your problem.  Also need to know the exact phone model.
http://www.telephonesystems.info/catalog/dept_id_43.htm?sid=A9BBC736C7CB1530F32066A82F4ACD5D&pid=1201
Posted on Nov 02, 2007
Lyle Siemens
  • 328 Answers
I am taking this problem with caution as you never said what model # your Lucent product is. I found some manuals that I hope can help.
http://www.baker.k12.or.us/technology/phones/mlx_user_guide.pdf
http://www.atelephonesystem.com/Manuals_Legend.htm
An easy way to re-rout your phone is obtaining a extension phone cord that will reach your room. The other option is to hire someone to install the line through your wall to the other room. If none of these manuals are of help, please list your model # and I will look it up for you.
I would like to know how to make a conference call
While your connected to the first party, press the Conf key.
press an idle line (or intercom).
call your next party.
press the Conf key again.
you can repeat steps 1-4 to add up to a total of 2 outside and 2 inside connections.
to remove the last added outside party from the conference press feature 06
Sep 13, 2010 | Lucent PARTNER18 Corded Phone
CHANGE THE TIME ON MY PANASONIC 7453
To set date and time on your phone system you must first enter user programming mode.
Using a display phone with the receiver hung up.
Press PROGRAM
Dial ** 1234 (SYS PROG NO)
Dial 000 (DATE AND TIME)
Press SP-PHONE key once (display shows current date)
Normally this is correct if not dial the changes in with your keypad. Use the FWD\DND key to
move forward on the display and the CONF key to move backwards.
Press AUTO DIAL STORE (Confirmation tone)
Press SP-PHONE key once (display shows current time flashing on hour)
Dial new hour (Two digits) Use the FWD\DND key to move forward on the display and the
CONF key to move backwards. Dial in any changes and when your done:
Press HOLD (SYS PROG NO)
Press PROGRAM
Your phone should be back to normal.
Mar 14, 2010 | Panasonic KX-T7453 Corded Phone
How do I enable caller ID on a Lucent MLX 10DP phone system?
The CID comes from the trunk card and cabinet. It's probably a Legend or a Magix system. If you don't have the proper hardware, you need to order and program it.
Your best bet is to call your AT&T/Avaya/Lucent installer and check with them as it's beyond the scope of a free forum to give exact instructions.
Carl
Oct 14, 2009 | Lucent Merlin Legend MLX-10DP Phone
Lucent MLX-20L Extension Edit
http://dstech1.com/changing-the-name-on-an-extension/
A label can have a maximum of seven characters.
To administer Labels for Extensions from the System Programming console:
  1. Press Menu.
  2. Press System Program.
  3. Press Exit or Start.
  4. Press More or Right Arrow Key.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  8. Dial the extension number that you want to administer.
  9. Press Enter.
  10. Press Drop.
  11. Enter the label information for the extension number selected.
  12. Press Enter.
  13. Press Exit or Back.
  14. Press Home or Exit to exit programming mode.
Note: When programming on the system programming console, use the buttons next to the display to specify the letters A through I and punctuation. Use the line/feature buttons to specify additional alphanumeric characters for labels. Use the template provided with the System Programming console to see which line buttons correspond to which alphanumeric characters,
Dec 22, 2008 | Lucent Merlin Legend MLX-10D Phone
Need Lucent MLX-20L Manual
Every single manual is avalable from the Avaya website. The cabinet in the back room is either off-white or gray metal. If it's an off-white one, it's probably a Legend. If it's gray metal, it's a Magix. The manuals are HUGE. Most of my customers have an 8 1/2 x 11 Administrator's guide, and a little spiral bound set user's guides, both for the console and the MLX-28DP phones.
Search around your place and see if someone has one squirreled away.
Carl
Dec 09, 2008 | Lucent Merlin Legend MLX-20L Phone
Mlx-20l
Visit support.avaya.com, search for your particular system and you can download a pdf of the manual
Jun 26, 2008 | Lucent Merlin Legend MLX-20L Phone
I can't change from night service to normal service
Are the keys not working? These phones have a common problem with the keypad locking up. If so, the keyboard membrane would need to be replaced. Temperature and humidity effects this problem greatly. You could try putting the phone in a freezer for a few hours to see if you can temporarily get the buttons working to put your system back into day mode. You will still need to get the phone repaired.
Feb 25, 2008 | Lucent Merlin Legend MLX-20L Phone
MLX-28D Corded Phone Change Time
The time is stored on the phone system, not the phone. You first need to know which phone system you have. This phone will work on a few different Avaya phone systems (AT&T and Lucent are now Avaya)
You can find all the manuals for free at www.avaya.com but you first need to know which system you have.
Nov 06, 2007 | Lucent Legend MLX-28D Corded Phone
Lands Phones Logo
57 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
