Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Power light flashing once
My panasonic th-42pd50u has the power light flashing once then pausing.
Posted by tjfitz on
  • tdiess Nov 22, 2007
    all of the sudden the tv just turned off wile i was watching it. i tried to power down the tv by unpluging it and the disconicting all the devices. but nothing seems to work. all that happend when i turn on the tv is the power light blinks. im out of ideas.....
Anonymous
My problem turned out to be the D board. I purchased one on Ebay for $100, replaced myself. The service technician charged me $90 to come out and tell me the problem then wanted $700 to replace the board.
Posted on Dec 04, 2007
Teltos
  • 5 Answers
Ouch...ok a one blink code could be either the P (power board) or the SC (scan board)...only a service tech call can tell you for sure. Ask around for some quotes first.
Posted on Dec 03, 2007
Red light flashing 10 times
The tv power supply board is the causes and the problems.That the board where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Feb 25, 2011 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Plasma tv th-42pd50u not come on and keep blinking red light two times and then stop again blinking red light two times and then stop not come on
The light blinking twice means there is a fault within the system and it is a code to tell Panasonic where roughly the fault lies.
Go to Panasonic's web site and look for your set then input the fault code and hopefully they will tell you where the fault lies.
Oct 16, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Oven will not bake but everything else works fine
What is the red light blinking? Count the blinks before it pauses and post back here. It'll give me and everyone else a starting point.
Jan 21, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
TH-42PD50U 42" plasma from Panasonic. The TV tipped over and won't turn back on. The red power light just keeps flashing on and off.
Try to unplug and replug the power cord. If TV remains unchanged you need to call for service. The power supply board was defective. In worse case, the Y and buffers are defective, too. There are many steps needed to figure out the exact defective board. You need help from TV repairer unless you want DIY.
Aug 13, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic Viera TH-42PV30 No picture & Stand-by light flashes 4 t
I would guess a power board failure. The blinking light is an error code.
Nov 17, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
No power
If your model number is TH-42PD50U, It is very hard to diagnose the symptom.I can direct to you where is the possible cause is.
For 7 blinks pattern may have trouble with SU or SD board or it could be SC board or Power Supply
Sep 17, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Power light blinking 2 times
2 blinks means the unit is having problem with 12 volt supply.
while power on you can check 12DC on power supply before shutdown.if the voltage is constant before shut down I would recommend to replace D board.
Sep 16, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
207 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Ekse
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
