Question about RCA P61960 61" Rear Projection Television
Were can i get the seal for the crt that is leaking coolant
My Rca rear projection screen TV Is leaking CRT coolant through one of it's seals ,were can i gat this seal from to replace ?
Anonymous
  • 61 Answers
If the front seal is leaking part number is 254599,the main seal,Thomson does not have ,replacement of the tube is required,mcm electronics should have the front seal,number is 1-800-543-4330
Posted on Mar 07, 2008
Testimonial: "kool"
Our rca hdtv monitor will work for approximately 15 mins before turning itself off then on and off again two more times. also the left side of the screen is starting to show a little more blue than usual....
pidksmith,
If you see something leaking from the blue tube it is probably coolant. You will need to find the leak and repair it and fill it with the proper amount and type of coolant. Projection TVs with CRTs have to have coolant covering the face of the CRT or they will overheat. Sometimes they can develope a leak. You will need to unplug the unit and remove the rear lower cover. Looking at the blue CRT from the top you should see 4 screws holding the lense on to the crt. Do not remove any other screws or you will change the mechanical focus. Remove the lense and look for the leak. If it can be fixed use good epoxy to seal it. Order a bottle of CRT coolant from http://www.mcmelectronics.com . There should be a filling port on the top of the crt. Fill the chamber to the required level, close, reassemble and you should be back in buisness. If the leak cannot be fixed you would have to replace the crt. I have a tip for that at http://www.fixya.com/support/r4573850-change_crt_in_projection_tv which explains how to do this.
Thanks for using FixYa and for the great rating.
hardrocko
Mar 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a light red hot spot just right and above center, any idea how to repair?
You have to take front projection screen off of tv. When you have taken screen off, turn on tv and observe light coming from the three crts. Look into the face of each crt and you will notice some contamination inside face of one of the crts. Most crts are sealed, so youll have to replace the burnt crt causing spot on picture.
Aug 19, 2010 | RCA P52926 52" Rear Projection Television
Liquide coms from RGB back projection tv.
The CRT will need to have new Coolant and new seals installed, and any circuit boards that were dripped on will need a very detailed cleaning to remove any residule as it can ruin the circuit board traces and solder connections
Jun 18, 2010 | Samsung HLR5087W 50" Rear Projection HDTV
I would like to buy a rca 61 P61960
Hi jkclay841 i live new york and have a RCA REAR PROJECTION TV 61" MODEL # P61960 CHASSIS NUMBER PTK195Y06T
IT POWERS ON BUT IT'S OUT OF ALIGNMENT ON ALL COLORS AND MISSING THE CLOTH THAT COVERS THE SPEAKERS HAVE THE REMOTE SCREEN IS IN GREAT CONDITION ALSO HAVE SOME NEW CRT COOLANT RUBER SEALS ,AND THREE NEW LENCES THAT I WAS GOIN TO REPLACE BUT CHANGED MY MIND PLUS NO TIME.
HERE IS MY NUMBER 347- 847 -3348 IM JOSE
Apr 03, 2009 | RCA P61960 61" Rear Projection Television
Change CRT coolant in AKAI Pt5598HD
The CRTs in modern TVs do not hold a charge because the HV circuit shunts it to ground whenever you power down the TV. You can clean the lens of the CRTs but you can't change the coolant or should you even try. You'll notice that its sealed from the factory. If you suspect a problem with the coolant or that it has dried up or leaked out, you must replace that CRT.
michtech
Feb 20, 2009 | Akai PT5598HD 55" Rear Projection...
Mitsubishi CRT
No, Yes mostly RCA,Yes ,must redo lense covers
Dec 19, 2008 | Mitsubishi VS-55707 TV
Toshiba 55 inch hdtv lamp
this is a crt type tv- no lamps just crt's if it was moved recently then a seal could have been damaged on the crt cuasing coolant to leak down the neck getting into the socket. this will cause trouble for sure also could have a crack in the crt. look for a sticky liquid in the bottom of the unit.
sometime the crt's can ark and rip out a video output chip on the crt socket check it out.
not common but not unheard of.cheers
Sep 26, 2008 | Toshiba 55H70 55" Rear Projection...
Crt coolant leak onto pwb
No xtended warranty .......common problem bad seal(s) allow
leakage from CRT(s) onto PCB (s)........CRT replacement needed and PCB repair.....check out MO/YR made on sticker on back of set .................!...................T.
Apr 15, 2008 | Samsung PCL5415RB 54" Rear Projection...
Leaking liquid
Sounds like your Blue CRT is leaking coolant.It will affect the hue for sure and it will also destroy your circuit boards as it is corrosive. Clean any coolant that has spilled onto your Chassis before it causes corrosion. You can buy coolant to replace this, however you will need new seals. This is a proceedure you may be able to handle if you are dilligent and pay attention to details. Replacement coolant can be purchased at the following Link
http://www.matelectronics.com/ or this link http://electronix.com/
The seal will probaly have to be orderd through RCA, I am not sure if the links mentioned carry the seals or not you might give them a call to inquire. If I can be of any addittional help let me know.
Jan 05, 2008 | RCA HD52W59 HDTV Projection Television
Leaking ploy silicon
Yes and that stuff is poisionous. So be careful, not to get on hands, if do clean really good, it's antifreeze like you put in a car. It's called CRT coolant, and it keeps the bulbs cool in your set. Yes it's repairable, If you get it on the circuit board it will damage your tv. You must clean completely if dropped on PCB. You can purchase at places like MCMelectronics, bluestar-online, tritronics etc. While leaking it must be a bad seal need replacing or screw loose.
Oct 09, 2007 | RCA P52926 52" Rear Projection Television
RCA P61960 61" Rear Projection Television Logo
178 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
