Question about Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
Will not turn on -- no power
Had a power outage, and now the TV will not work. Other items such as radio, playstation plugged into the same outlet are working. What could be wrong, TV is only 10 months old.
Posted by MWig on
  • 1 more comment
  • Anonymous Dec 07, 2007
    Out of the blue, the TV turned itself off. As I was in the next room, I did not hear or see anything abnormal. All it does now is make a slight hum/buzz, which can barely be heard when it is plugged in. The unit is either 1 or 2 years old this month.
  • Anonymous May 08, 2009
    Our TV does the same thing! Everytime we have a power outage, or just unplug the TV. It's done it for several years. It always comes back on after a couple of days. Ghost in the machine ;-)
  • carol228
    carol228 Jan 26, 2013
    Ours went out after a storm and we can't get it to come back on at all, and it's been unplugged for weeks. Is there any kind of "reset" button?
Cary Farah
    President:
  • 4,402 Answers
Check for blown fuse inside if thats no then you need to trouble shoot the power supply
Posted on Dec 07, 2007
Viore tv won't power up after power outage.
I would first test the outlet. Unplug the TV and plug in your vacuum or other loud or bright object. Turn on test object - if there is no operation, then you have a tripped circuit breaker. Find the electrical panel ( Grey box mounted into a wall, usually in a closet). Find the tripped breaker ( typically the switch will be halfway between on and off, and many have a red indicator by the switch base). Turn switch to off fully, then back to on.
Retest outlet.
If still no power to outlet, unplug everything from that outlet and call an electrician - there may be a serious problem with the wiring!
Hope this helps!!
Dec 02, 2013 | Televison & Video
We are have power outage and we can't get our 50"
Have you tried unplugging the TV from the wall for 5 minutes?
Also have you tried plugging something else into the outlet to verify that the outlet works?
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | Televison & Video
Olevia LT20s
Check power outlet. Connect TV to a different power outlet. Switch off TV manually, switch off power input, remove plug and cool it off for 48 hours and retry. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Televison & Video
No color
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc.
Jan 15, 2011 | Memorex MVDT2402 24 in. TV/VCR/DVD Combo
No sound output need sound unit
Jan 14, 2011 | Mintek DTV-233 23 in. TV/DVD Combo
We had a power outage today and our tv won't turn on - there is a green flashing light on the front panel and that is it.
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 18, 2010 | Televison & Video
Our electricity went out and now we have it back on
Most times when a power outages occur, most everything that's plugged into an outlet receives a "Power Spike". Basically it's a shock wave traveling through the neighborhood power grid when the electricity turns OFF and ON.
Hopefully the TV didn't receive too much damage. Inside the TV, there is a fuse that may need to be replaced. Radio Shack or other electronic store will carry these fuses. If this doesn't solve the problem, the Power Supply Board maybe damaged.
Jan 28, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
There was a power outage in the middle of the night. My computer was turned on during the outage (Presario 2200). Now it will not turn on ; it is plugged in (was in a surge protecting power strip during...
Please try to remove the battery and than try to switch on the laptop directly from mains power and if it works than its your battery problem or if it still not starts than there is possibility of some components of your laptop may fired due power fluctuation. So go and contact service station.
Jan 08, 2009 | HP Compaq Presario 2200 Notebook
TV wont turn on due to power outage
I know it's been a while since you have sent this request, but if you havn't gotten any help or repaired the set by now, I'll try to help if I can. Your set has a seperate power supply board internally. The fuse could be burned out on that board. Also if you did in fact get a power surge, you may have a capacitor or a series of capacitors bad. Check the fuse first and if this is not the problem, I suggest you replace the power supply board as they are not real expensive. Good luck and I hope this has helped in some way
Ed Meshechek ( Radio Man )
NC Electronics
Mills, Wyoming
307-266-4675
Jun 01, 2008 | Olevia LT37HV 37 in. HD-Ready LCD...
Sylvania 6720FDD 20 in. TV/VCR/DVD Combo Logo
247 people viewed this question
Top Sylvania Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
